02-10-2023, 09:53 PM | #23 | |
I Shoot People For Money
1049
Rep 1,917
Drives: 2023 Portimao MSport X1
Here's another site, you can email them and ask which ones fit the X1: https://www.ecstuning.com/Search/Sit...h/wheel_locks/
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
06-04-2023, 06:52 AM | #24 | |
Rep 623
Drives: BMW iX1, U11
Some questions for you: Have you managed to drive with these? How are you liking them? Any hit on the range? And finally, are these the Z-Performance ZP2.1? Thanks! |
09-09-2023, 02:37 AM | #25 |
Rep 54
Does anyone live close to TIRE RACK headquarters in South Bend, Indiana? So they can take the x1 to their headquarters for fitting purposes as their email response to me say they likely will have not have rims available on the site until after the winter season...
Re: Question for Sales From www.tirerack.com - ##RE-212749## Yahoo / Inbox Tire Rack Sales <saleshd@tirerack.com> To: Fri, Sep 8 at 10:15 AM Unfortunately we wont have any info on wheels we carry that fit until the car is sent here for the engineers to measure. Going into the winter season, that may not happen until the beginning of next year unless a local customer with the vehicle brings theirs in to pull that information from the car. Description : [EXTERNAL EMAIL] DO NOT CLICK links or attachments unless you recognize the sender and know the content is safe. Below is the result of your feedback form. It was submitted by on Thu Sep 07 03:23:15 EDT 2023, app10-ign_retail1 User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 Edg/116.0.1938.69 --------------------------------------------------------------------------- Question: re: rims for a 2023 bmw x1 28i (none available at present for sale) Hello, when will Tire rack have a supply of rims in the 19 inch sizes? I am looking for an all black colored wheel rim 19x8 or 19 x 8.5. Please let me know if anyone knows as to when it will be posted on the website.. thank you so much ! |
09-09-2023, 03:20 AM | #26 | |
1049
Rep 1,917
Fitment should be similar to the F48 X1 from what I've read. I currently am running 19x8.5 BBS RGR's ET32 and they are flush with the top of the fender with plenty of clearance with the suspension. In keeping with the preprogrammed accepted sizes in the TPMS system, a 245/45/19 tire is the ideal size. I personally don't buy from Tire Rack unless I have to, their shipping to Hawaii is pretty steep. Amazon Prime ships tires though! Got my Hankook Ventus V12 evo2's from them last month.
09-09-2023, 01:30 PM | #27 |
Rep 82
A quick question I have, and I think there's some debate over this in another thread, but did any of you who did swap out for aftermarket wheels, upgrade your lug bolts as well?
09-09-2023, 04:41 PM | #28 |
1049
Rep 1,917
I swapped to a stud conversion and lug nuts. OEM thread pitch is 14x1.25, I got a conversion stud set that changes the wheel mounting side to 12x1.5 since there are much more readily available lug nuts in that size. They’re also longer than stock length so I had the option to run spacers if needed, and I got some Project Kics open end lug nuts with a floating seat to help with ease of centering and reduce wear on the paint of the lug seat.
09-09-2023, 09:24 PM | #29 |
SeattleBMW
101
Rep 99
In the case of a wheel swap, the most significant variable to trigger the need to renew lug nuts is the type of seating used in the wheel that is replacing the original. Ie if your Oem set up uses conical seats (as in the case of the X1) and your replacement wheels use ball seats, then change the lugs. If you plan on using spacers to make up for an offset issue, then change the lug length commensurate with the spacer width.
FlashMonkey9291048.50 |
09-10-2023, 03:57 PM | #30 | |
slowest X1 driver ever
494
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
09-10-2023, 11:18 PM | #31 |
SeattleBMW
101
Rep 99
I recall running some forged HREs on one car and called them on torque settings (as they were forged)….the tech said go ahead and use manufacturer specs as I was using exactly the same lugs. I’ve applied that answer in every case including when I change the lugs and not had any issues.
09-11-2023, 12:39 AM | #32 | |
1049
Rep 1,917
12-11-2023, 01:27 AM | #33 | |
Rep 2
12-11-2023, 03:14 AM | #34 |
1049
Rep 1,917
Here you go. I posted them in one of the threads but it’s probably buried somewhere.
timesone184.50 |
03-22-2024, 12:27 AM | #35 | |
Rep 13
03-25-2024, 04:23 AM | #37 |
1049
Rep 1,917
You shouldn't have any issues as long as you stay with the proper sized tire diameter.
03-27-2024, 09:46 PM | #38 |
Rep 11
03-27-2024, 09:50 PM | #39 |
1049
Rep 1,917
No, they are not, they vary from model to model. For the U11 X1 I believe they are all the same, however if you want the wheel to be more flush or more inset into the wheel arch you'll have to do your own calculations on what will fit. There are many helpful articles online if you google "calculating wheel offset"
GX1.50 |
03-30-2024, 02:24 AM | #41 |
1049
Rep 1,917
What are the other specs of the wheels? Diameter and width are important. An offset of 27 will technically fit, but will protrude from the wheel arches slightly. But if the wheel diameter is too wide you may have clearance issues with the suspension, that’s why the full specs of the wheels are important.
03-30-2024, 08:09 AM | #42 | |
Rep 11
03-30-2024, 08:13 AM | #43 |
1049
Rep 1,917
They’ll mount on the X1, but they will protrude from the fenders a bit I think.
