BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) 826M cleaning?
      01-23-2023, 10:50 AM   #1
FDfranklin
d[-_-]b
FDfranklin's Avatar
503
Drives: Ordered: 2023 G80 M3 6MT
826M cleaning?
Okay, not much of a car washer but want to keep the G80 pristine.
Did the Garry Dean method for my first wash and the car is looking damn good.
Went to clean the wheels and gave up ( microfiber towel with ONR ). So many nooks and crannies...
What tools are you guys using to clean these?
      01-23-2023, 11:21 AM   #2
John @ BSPK
BIMMERPOST Sponsor
John @ BSPK's Avatar
894
Drives: 2023 G80 6MT
This is the best tool IMHO (I’ve tried a lot of them)
https://a.co/d/inoUVsv
Many coats of ceramic are necessary though (just cheap self applied stuff works wonders). The best tool is no tool if you can get a hose to work (lots of ceramic coat is necessary for this though)
      01-23-2023, 11:29 AM   #3
dr1ven
dr1ven's Avatar
307
Drives: 2023 BMW M3 Comp
I would not use ONR waterless to clean wheels. Brake dust is extremely abrasive and it gunks up microfiber clothes very quickly.
I recommend using a non-acid based wheel cleaner with iron contaminant removal properties. Then rinse off and use snow foam to lubricate the wheel while you use a wheel woolie or two to clean the wheel properly. Rinse and then use a microfiber for finishing.
Cleaning wheels properly is a huge pain and these wheels are on the harder side.
Ceramic coating will help considerably but it won’t allow for 100% contactless washing, in my experience.
      01-23-2023, 11:54 AM   #4
FDfranklin
d[-_-]b
FDfranklin's Avatar
503
Many coats of ceramic are necessary though (just cheap self applied stuff works wonders). The best tool is a no tool if you can get a hose to work (lots of ceramic coat is necessary for this though)
Thanks will give that tool a try.
      01-23-2023, 11:56 AM   #5
FDfranklin
d[-_-]b
FDfranklin's Avatar
503
Have any recommendations for some of those products?
      01-23-2023, 12:27 PM   #6
astroricardo
astroricardo's Avatar
Drives: 2022 M3Cx TR/Tartufo
Links to CG for illustration only, replace with your vendor of choice
Wheel brush for 'barrels'
https://www.chemicalguys.com/red-roc...%20Suggestions
various size wheel woolies for wider areas
https://www.chemicalguys.com/wheel-w...Best%20Sellers
wheel wash mitts for everything else
https://www.griotsgarage.com/microfi...itts-set-of-2/
plus whatever wheel/wheel and tire cleaner of your choice.
wish I would have sprung for CCBs sometimes, it's a bear man
      01-23-2023, 12:28 PM   #7
dr1ven
dr1ven's Avatar
307
Sonax Wheel Cleaner or P&S Brake buster are both good. brake buster can be diluted and is way cheaper.
For snow foam I really like gyeon q2foam.
MannyS367.00
