bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      01-23-2023, 04:22 PM   #1
yuvalt
Drives: 22 M240i, 09 Miata, 70 Corvett
Vibrations at high speed
Hey,
So I've been having vibrations in the car when driving 70mph (2022 M240i). Took it for a service... first thing was two front rims are bent, then they re-balanced and aligned the wheels. It's better but still vibration. They say the tires have shifted belts in the tire (something I never heard of), and I should replace both front tires, and that it's not covered by road hazard insurance..... the car did ~6000 miles since I got it last February. I don't remember going into deep potholes, just the regular NJ roads
Does this make sense that I have this damage after this milage? How can I avoid it? I never had this kind of damage in other cars I owned (Accord, GTI).
Any advice is welcome. Thank you
      01-24-2023, 12:35 AM   #2
tahoeacr
Drives: 23 M240IX
First thing I would do is switch the front wheels to the back. If it changes, they're right. I would just want a little piece of mind for myself before I spend money.
Forgot about the off set difference. Could always go left to right. Even then it should make a difference. The rims aren't going to be bent exactly the same.
      01-29-2023, 05:40 PM   #3
BG42
Drives: M240ix
Could always try to find an indie shop that can high speed balance them see what they say.
      01-30-2023, 01:36 PM   #4
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
If you have "shifted belts" you should also feel it at very low speeds (parking lot speeds) on a real smooth surface. It should feel a little lumpy or 'out of round' with each wheel rotation.
g87
