01-31-2023, 07:57 AM | #1 |
Rep 51
Brakes locking after sitting overnight!
When I put it in drive and diengage the parking brake and go to pull off it won’t move ., I have to give it some gas and hear a loud pop from brakes then it will move . Anyone else experience this? Fine the rest of the day. Just over night. 🤷🏾‍♂️
01-31-2023, 07:59 AM | #2 |
Rep 140
was it wet? That's normal if you wash a car or drive through the wet and park it. It's just the surface rust of the rotor against the pad.
nearwater4me1924.50 stevebmw301844.50 |
01-31-2023, 08:06 AM | #3 |
Rep 2,142
Probably this. I normally make a few hard brakes to wipe/heat off the moisture before parking the car in the garage after a wash.
davidmct-M3237.00 |
01-31-2023, 08:15 AM | #4 |
Rep 3,626
Its the stick slip phenomenon with brakes.
It can be common in performance vehicles due to the combination of material used in pads and calipers under moist conditions. |
01-31-2023, 09:39 AM | #6 |
Rep 1,807
Does your car have the auto hold feature? That is what this sounds like.
01-31-2023, 09:44 AM | #7 |
Rep 324
nearwater4me1924.50 |
01-31-2023, 09:53 AM | #8 |
Rep 1,112
01-31-2023, 10:31 AM | #9 |
Rep 2,044
Yep..learned it the hard way. Did a car wash when it was 30F outside and when I came back in 4 hr, car wouldnt move in reverse. Had to give a fair amount of throttle to move it and was afraid I was gonna back into the car that was parked behind me on the opposite row. Luckily the brakes were still good to stop..lol
01-31-2023, 12:27 PM | #10 |
Rep 2,142
02-01-2023, 11:19 AM | #12 |
Rep 720
OP, Now that you know to dry the brakes after washing the wheels, I had to replace a set of brake pads on my 535I because a chunk of pad material came off after a loud pop from them sticking overnight from not drying it.
Check your pads and make sure they are intact.
2023 G80 M3 C/XD SMB, 2012 F10 535i M-Sport, BM3 stage 2. 2014 Porsche Cayenne GTS.
