jb3 install problems
01-07-2009, 09:56 PM | #1 |
Rep 3,588
so today i figured i would just give it a shot and install it (pinout version)
so everything was very straight forward i thought i did everything perfectly and the wires in the correct locations etc, triple checked everything so its time to start it up Just cranks and cranks i check Burger Motorsports website for troubleshooting cranking means ecu not connected or loose wire check everything again still nothing so i decided to take the JB3 out and go back to stock so wire up everything back to stock STILL CRANKS!!!!!! will not start guys please any thoughts any clues idea's guys i'm really scared i broke something and really don't got the $ to repair it if something did go wrong car is currently broke down in a shop about 15miles from me |
01-07-2009, 09:59 PM | #2 |
1750
Rep 17,960
Drives: A Lot
I know this sounds stupid, but make sure the ECU plugs are pushed on the ECU all the way. And the sliders closed so that it clamps on the ECU. The reason I suggest this is because it is very hard to get the car not to start-up at least. It may take a bit of cranking and may throw a bunch of codes but the engine should eventually start. The only times I've seen the engine just crank and crank and crank is if the ECU isn't plugged in.
Hope that helps. Shiv |
01-07-2009, 10:01 PM | #3 | |
Rep 657
/// E92 | JB4 | UR DP | BMS DCI | H&R | LC Z2S | |
01-07-2009, 10:01 PM | #4 | |
442
Rep 18,331
01-07-2009, 10:12 PM | #6 |
1750
Rep 17,960
Drives: A Lot
oh yeah... and get a PnP harness if you can. It would certainly rule out a dozen or so possible problems. And make your life a lot easier in the long run. These days, there is absolutely NO reason to go pin-out. Just asking for trouble, imho. Especially now that fuel pressure is intercepted in kits.
Shiv |
01-07-2009, 10:16 PM | #7 | |
208
Rep 9,339
01-08-2009, 11:14 AM | #11 |
Rep 3,334
+1 on the ecu connection problem, make sure it seated properly if you are forcing it you are not doing it right. It should slide in and connect without any force at all.
Mods list got too long, lets just say more than enough.
01-08-2009, 12:10 PM | #13 | |
Samtaro!
125
Rep 2,601
Its also possible to slide the multipin connector into the slider assembly incorrectly... so that no pins in the connector can reach the ECU. I did that once...
01-08-2009, 12:11 PM | #14 |
Rep 870
wow, we've got very similar car options, odd mix of stuff, cool, good luck with the JB3, it's a great tune.
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 / Center Armrest Pouch / JB4 / BT
