02-09-2023, 09:41 PM | #1 |
Rep 1,163
Perhaps a dumb question.. happy to delete the thread if so… but given some reports of blown struts from HAS kits and front lowering springs (and subsequent dealer warranty replacement denials)… is there a way to modify the existing front springs in a way that would be undetectable by the dealer? Could you heat up and compress the springs so that they are effectively a half inch lower than normal but seem normal at quick glance if ever needing a strut replaced?
02-09-2023, 10:43 PM | #3 | |
Rep 7,033
Drives: 2022 DG/BLk xDrive M4C Wk 34
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
02-09-2023, 10:53 PM | #4 |
Rep 1,163
Yea def leaning more in that direction now. The 10mm drop they recommend is too tucked for rear and not low enough in front. If I did 5mm in rear and 20mm in front would I still retain warranty as it’s within the range of what’s possible with the MP HAS?
02-09-2023, 10:58 PM | #5 | |
Rep 7,033
I don't think BMW would sell something that allowed you to drop if more than the engineers believed the suspension could handle. If it does blow one, raise it up.
YT: G Dubyou |
02-09-2023, 11:04 PM | #6 | |
Rep 1,163
Limegrntaln13707.00 |
02-09-2023, 11:10 PM | #7 | |
Rep 7,033
YT: G Dubyou |
fanofbmwe462104.00 |
02-10-2023, 12:55 AM | #8 | |
Rep 788
02-10-2023, 02:33 AM | #9 |
Rep 7,033
Nik, it's only going to get worse if you go lower. I dont go into SF, so, I'm good.
YT: G Dubyou |
Nkr151124.50 |
02-10-2023, 11:01 AM | #10 |
Jedi Knight
2210
Rep 375
if you wanna go LOW without issues, you'll need coilovers. very happy with my KW V3. but very unhappy with the price of them haha
02-10-2023, 11:33 AM | #11 |
Rep 1,961
Are there any markings on the front springs? Perhaps the eibach front only springs might fool the techs since they're both black.
02-10-2023, 02:55 PM | #12 |
Rep 1,163
02-10-2023, 02:57 PM | #13 |
Rep 1,163
What’s the cost to replace a blown front OEM strut?
With how cheap eibach front springs and install is, I could prob through two strut replacements before it would get to the cost of the MPHAS kit installed at port ($2820) |
02-11-2023, 05:07 AM | #14 |
Rep 311
If you go with the MP HAS kit, you are under warranty from BMW (and even more with a dealer install).
The -10mm drop is a recommended drop, not a MAX one, for everyday use + trackdays. You can go lower, that's not recommended for obvious daily usage according to BMW. But that does not void the warranty. Nothing in the install PDF says so.
Current: 2023 ///M3 Competition xDrive - SSG
fanofbmwe462104.00 Limegrntaln13707.00 |
