02-22-2023, 11:02 AM | #1 |
Rep 22
Rear Brake pad change, question/help?
I like to do most of the basic maintenance work on my cars instead of taking it to a mechanic but this is my first BMW and anything with an electronic parking brake and there is no real detail information, so I am asking for help if anyone here can.
I know that after I take the motor (electric ebrake) off the caliper, I turn it clockwise to press in the piston. The question is, do I turn it back to the original position or leave it the way it is. Does the car automatically readjust itself? Also, do i have to put the car in service/diagnostic mode prior to doing the brakes? Sorry for the newb questions. |
03-01-2023, 04:34 PM | #2 |
Rep 83
If you can put the car in to service / diagnostic mode then you don't need to remove the motor from the caliper.
I use BimmerLink and a wireless OBD II connector, when you put the car in to the service mode, the rear calipers parking brake motor automatically retract all the way. If you remove the cap from the brake fluid reservoir its super easy to push the brake piston back in manually, just be careful / go slow. if you had to remove the motor each time i would be going crazy. |
ATX_M3185.50 Chubbiejones894.50 |
03-04-2023, 07:15 PM | #3 | |
Rep 22
03-07-2023, 05:30 AM | #4 |
Rep 280
Drives: 2023 M3 Comp
I guess anything could happen, but Bimmerlink is just diagnostic scan software used with the OBD II port auto manufacturers are required to put into vehicles. I would find it very hard to believe that using this would ever void a warranty. I guess if you used the wrong cable/dongle and messed something up, but it's a pretty straight foreword process.
03-07-2023, 08:45 AM | #5 | |
Rep 106
Drives: 2023 M3 Comp X-drive
The round disks in this kit (as an example) are used to compress and rotate pistons. |
03-08-2023, 04:17 AM | #6 | |
Rep 22
good to know, thank you |
