BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Problem with Apple Maps integration
      02-23-2023, 08:34 AM   #1
bfaliszek
Drives: BMW X1 U11
Hi!
For some reason, the deep integration(on the screen behind the wheel) of Apple Maps via CarPlay does not always work correctly on my X1. Sometimes it gives me a message like in the first picture(text translation: "Route guidance via Apple CarPlay active"). When I drive a bit and get on the return route, or get out and get back in the car (it's important that the screens go black for a moment), full integration starts to work. Anyone know why this is happening and what to do about it?
Apple Maps on the center screen always works correctly.
Remote Software Upgrade: 11/2022.44
      03-10-2023, 11:07 AM   #2
ceevee
Have you solved this?
      03-10-2023, 11:46 AM   #3
tex2670
tex2670's Avatar
Drives: '23 X1 28i xDrive
Interesting. That seems to be a different problem than this one:
https://u11.bimmerpost.com/forums/sh...&highlight=gps
      03-10-2023, 12:28 PM   #4
bfaliszek
Drives: BMW X1 U11
So far, restarting iDrive (pressing the volume knob for 20 seconds) helps. Usually it helps for several days
      03-10-2023, 12:29 PM   #5
bfaliszek
Drives: BMW X1 U11
The GPS in my iPhone works without a problem during wireless charging
      09-13-2024, 12:30 PM   #6
Heera
Heera's Avatar
Drives: X1
I've never been able to get apple car play Google maps to come on to my BMW display. Just says route guidance via apple car play. Anyone know why?
      09-13-2024, 12:35 PM   #7
tex2670
tex2670's Avatar
You can only display Google Maps on the main screen. Only Apple Maps and factory satnav can display in the instrument panel
      09-13-2024, 01:07 PM   #8
FZI89
FZI89's Avatar
Austria
717
Drives: BMW iX1, U11
If you have android: Google maps will appear on instrument panel.
If you have iPhone: Apple Maps will appear on instrument panel. You cannot have Google maps on the instrument panel when using CarPlay
      09-13-2024, 02:48 PM   #9
SnowCover
Drives: '23 330i, '23 X1, '25 X3
new iPhone 16 pre-order started several hours ago.... I hope you're not trying to convince the guy to convert to Android phones. Mr. Cook wlll not be pleased.
FZI89717.00
      09-13-2024, 04:19 PM   #10
FZI89
FZI89's Avatar
Austria
717
Given the issues with CarPlay and android auto in iDrive 8 and 9, either option is fine hahaha
I’ve stuck with the OEM satnav and it’s been great. Especially with the augmented reality navigation and built-in charging planner
Also, (without starting an OS war &#129315, I just want to clarify that I’d never recommend an Android phone over iOS. Even though I absolutely love the phones and features, the software just lets them down in comparison.
      09-13-2024, 04:23 PM   #11
SnowCover
Why are you "stuck" with the factory satnav?
      09-13-2024, 04:40 PM   #12
FZI89
FZI89's Avatar
Austria
717
My bad. I meant I’m sticking with it. Not that I’m stuck with it. No negative connotation.
      09-13-2024, 04:52 PM   #13
SnowCover
ok, that makes more sense.
I use all three, depending on location.
I use the BMW factory navigation when I'm in cities becasue the AR makes it easy to navigate.
On highways/interstates for long distance driving, I go back to Apple Maps.
When I'm in an unfamiliar city, I use Google Maps because it's much easier to search for restaurants or attractions on Google Maps.
FZI89717.00
      09-13-2024, 04:58 PM   #14
FZI89
FZI89's Avatar
Austria
717
Nice use of the three maps! In the year and two months I’ve had the car I think I needed to switch to Google maps about once or twice and it was for the exact reasons you use Google maps. I was in an unfamiliar area and trying to locate a restaurant. The bmw maps was taking me to an area that was 5 mins away from the real location. Was very weird
SnowCover159.50
      09-13-2024, 05:09 PM   #15
JayZe
Drives: BMW X1
I have the same problem.
it says that it found the restaurant but then guides me to a wrong address.
Besides that, works very well and it is very user-friendly.
FZI89717.00
      09-14-2024, 11:21 AM   #16
tex2670
tex2670's Avatar
Factory nav is inferior.
There's a turnpike exit near me that, when you get off the exit, you can stay all the way right and go North, or get off the exit and bear left, and go South. Or, of course, you can stay on the highway and not exit. Factory nav says "go left" if you stay on the highway, and "go straight" to exit and then bear left.
Brilliant. Just one example. It tried to take me thru a construction entrance (temporary gravel road) to a resort last year.
      09-14-2024, 12:06 PM   #17
SnowCover
but the AR feature is fun because of the big arrows.
otherwise, yes, it is inferior. map data is somewhat outdated. or in some cases, severely outdated and attempts to take me on roads that have not existed in over 4 years. the interstate entrance was relocated and the original entrance became an empty field.
I dont' know if it's just me, but there are times when I start driving and my phone won't connect to CarPlay. That means I can't use CarPlay for navigation unless I pull over and try to reconnect it. In those cases, at least the BMW factory navigation still works, so it's useful that way.
      09-14-2024, 01:36 PM   #18
tex2670
tex2670's Avatar
I have iDrive 8, which sometimes doesn't connect Apple Car Play. But all I have to do it hit the icon for Mobile Devices in the home screen, and tap the Car Play box and it connects right away.
      09-14-2024, 03:03 PM   #19
SnowCover
I have idrive 8 also. That trick doesn't always work for me. Sometimes it does work, but CarPlay will play music and answer my Siri command... while the screen is blank. I can even say "Hey siri, start navigating to Logan Airport" and it will start navigation and give voice instructions, but no maps appear on either screen. The only way around it to turn the engine off and start again.
      09-14-2024, 05:43 PM   #20
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1251
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
There's 3 locations that I frequently pass through in my area that have high levels of RF interference that causes CarPlay to disconnect, this happened on my previous f32, and even causes TPMS errors at one of the locations on my old e90 and e92. Two of these spots the RF interference is so bad that when CarPlay does reconnect sometimes the infotainment goes blank, yet music still plays and I can give Siri commands. If I restart the infotainment system by holding down the volume knob this will fix it, other times going into the menu and disconnecting the phone and then reconnecting it will work.
This is probably my biggest annoyance with the electronics, but thankfully only happens once or twice a week at most.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      09-14-2024, 06:59 PM   #21
markronnie
BMW Owner
markronnie's Avatar
Drives: 2024 BMW X1 28i
  [0.00]
2024 BMW X1 28i  [9.00]
Wow!!
Sounds like you might have bigger problems that CarPlay disconnecting.
I’d be afraid to drive near the 3 high RF areas you mentioned for fear that I’d be cooked alive or chocolate in my hand I’m eating would melt.
Sounds dangerous
      09-15-2024, 01:57 AM   #22
FlashMonkey929
1251
2023 BMW X1  [10.00]
Originally Posted by markronnie View Post
Wow!!
Sounds dangerous
I live on an island, so not much choice avoiding them. One is a radio station, one is a military hospital right near the freeway, and one I can't figure out where it's coming from but it's near the defunct stadium(which come to think of it, I haven't had any disconnects there since they shut it down this year). I'm not too worried about it, pretty sure there's way more things I encounter more frequently that will kill me first.
