02-28-2023, 04:09 PM | #1 |
Rep 367
M60 engine gauges
I found these engine gauges in my M60 under
Live Vehicle There's lb/ft of torque instead of ft/lb but evidently there's no difference. HP Engine rpm Battery temperature. So far I've only been able to pull 671 lb/ft of torque in Sport Mode, booting it on the highway, never mind the 749 lb/ft claimed in Regular mode by BMW. I'll have to try this a few more times but 78 more ft/lb would be nice. The engine rpm is 7200 at 75 mph The TQ and HP are on deceleration My battery temperature is between 90-135 F Has anyone else with the M60 checked their numbers? |
02-28-2023, 04:57 PM | #2 |
BMW Aficionado
1381
Rep 1,850
No but if it’s not raining tomorrow I’ll take mine to work and report back
deutsch1004088.50 |
02-28-2023, 05:18 PM | #3 |
Rep 367
deutsch1004088.50 |
02-28-2023, 05:19 PM | #4 |
Rep 681
I'm pretty sure that's motor temperature, not the battery.
deutsch1004088.50 xueju1121621.50 |
03-01-2023, 06:22 AM | #5 |
Rep 367
It doesn't mention these gauges at all in the owner's manual.
Typical. Somewhere I read that it's the battery temperature but I can't seem to find it. I'll do the battery pre warming/conditioning which should tell me which is which. |
03-01-2023, 03:37 PM | #7 |
Rep 367
03-01-2023, 04:49 PM | #8 |
Rep 1,994
03-01-2023, 04:52 PM | #9 |
Rep 367
03-01-2023, 05:24 PM | #11 | |
Rep 1,994
One notable difference, and the main reason I almost never used sport mode, is that it forces you to use regen when you lift off the accelerator pedal. Makes the ride jerky. I much prefer adaptive because it is as close as you can get to having that off and this seems unavailable in sport mode. EDIT the above about forcing you to use Regen is apparently not correct. See further posts for info. Last edited by ggalanis; 03-01-2023 at 07:02 PM.. Reason: Correction |
03-01-2023, 05:30 PM | #12 | |
Rep 681
ggalanis2527.50 |
03-01-2023, 05:41 PM | #13 |
Rep 1,994
Maybe I have to go change the setting while in sport mode to make it work in that mode too. I don't remember if i did or not to be honest. But I don't remember other drive modes doing this. I occasionally used digital art mode and it just kept the adaptive setting from before.
falconey Did you have to set it once, or each time you switch to sport mode? Last edited by ggalanis; 03-01-2023 at 05:48 PM.. Reason: Added question |
03-01-2023, 06:15 PM | #15 | |
Rep 681
ggalanis2527.50 |
03-02-2023, 11:50 AM | #17 |
Rep 1,994
