03-02-2023, 05:32 PM | #1 |
Rep 929
Problem With Apple Carplay Switching To Other Media Devices
When I am in the Apple Carplay mode, I have a hard time switching to other media devices such as Sirius, FM and so on. I must push the media button several times before the selection screen pops up, only then I could select, let’s say SiriusXM.
It will switch to Sirius and play but the screen still displays Apple CarPlay. If I push the media button again and select Sirius it will finally display the Sirius screen. My car is a 2020 M550i with 7/20 operating system. Is this normal? I wouldn’t think so. Thanks! |
03-06-2023, 09:06 PM | #3 |
Rep 929
Could someone press their media button to see if they could select another audio source, am,fm or sat. when CarPlay is running?
When I push the media switch it won’t switch to another source unless I push the button multiple times. I think I may have a software bug. Thanks! |
03-10-2023, 09:11 AM | #4 |
Rep 179
Press menu button and then go to Media.
Another issue, for which I don't have a solution, is if you keep using your phone, for example send a message via whatsapp, media will be changed to carplay from whatever else it was on. |
03-10-2023, 10:35 PM | #5 |
Rep 307
I switch between radio and Carplay often. I set a number to each and just press the number to switch instantly. Thant’s the best I could come up with.
Go to media hover over whichever you’d like and hold the number to set it. |
03-13-2023, 06:47 AM | #6 |
Rep 1
I am also facing a problem with Apple carplay switching to other media devices and I don't know why. I did my best to resolve this issue but failed every time. Recently, I was looking for a site online where I can get more info or reviews on the Papersowl essay writing service and while searching for it on Google search I found your post. I will try it as you said and I hope it works.
03-13-2023, 10:17 AM | #8 |
Rep 929
03-13-2023, 04:28 PM | #9 | |
Rep 1,182
