03-08-2023, 10:51 PM | #1 |
Rep 179
Steel braided brake lines and better brake fluid recommendations
I was wondering if any one upgraded there brake lines and fluid and if so can u point me in the right direction
03-12-2023, 06:20 AM | #2 |
Rep 751
I fitted these…
https://gbp.r44performance.com/produ...-lines-g42-g20 And, used this: https://www.opieoils.co.uk/p-894-mot...SAAEgLd3PD_BwE |
03-15-2023, 05:16 PM | #4 |
Rep 706
this is a link to a nice simple chart of comparison of many brake fluids showing wet and dry boiling points plus cost comparison.
What's nice is it shows the specs on BMW dot4 fluid as well so you can compare to stock. https://www.lelandwest.com/brake-flu...ison-chart.cfm |
03-23-2023, 03:20 PM | #7 |
Rep 706
It's a somewhat common change on motorcycles, (rubber to stainless), it gives you a more positive initial feel and reduces any soft or sponginess in the brake feel (at least on bikes).
04-04-2023, 09:44 AM | #8 |
Rep 271
I have tracked my M240 5 times and thought I needed SS Brake Hoses, however I'm still on stock hoses and so far they work fine. I did upgrade the brake fluid. The HEL hoses are not DOT specs, for whatever that might be. I believe these hoses are the same as the G20?
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
