03-16-2023, 04:24 PM | #1 |
Rep 3
Wheel size for awful roads
I'm a fast driver and live in Chicago which has aweful aweful roads with potholes. How are the rims on BMW M2s/M3s?
I put in a reservation for the new M2 but am super worried about the huge 19in rims up front and 20s in back. Do dealerships have options to downgrade rim size? |
03-16-2023, 04:47 PM | #2 | |
Rep 1,843
03-16-2023, 04:55 PM | #4 | |
Ghostrider
190
Rep 142
Drives: M140iX,Z4M40i,M8 comp,M2g87
https://www.alloywheelsdirect.net/bm...el_6957#compat Last edited by Ghostrider.1127; 03-16-2023 at 05:40 PM.. |
03-16-2023, 05:30 PM | #5 | |
Rep 42
boss_royce0.00 |
03-16-2023, 05:55 PM | #6 |
Rep 407
Just get the tire and wheel warranty the finance officer will push on you.
You must be downtown? I’m in the burbs and the roads are pretty great out here (when not under construction for 10 years in a row). |
boss_royce0.00 |
03-17-2023, 02:00 AM | #7 |
Rep 755
I'm thinking about getting 19" Apex front and rear. I don't think a 20" rear looks any better than a 19.
Expert@ApexWheels3561.50 Mike_H_264.50 |
03-17-2023, 04:36 AM | #8 |
Rep 1,843
I was thinking this as well earlier, but noticed the weight of the 285/35 also increased 2lbs so there's a bit of offset performance/weight wise. Should be more comfy though.
03-17-2023, 05:41 PM | #9 |
Rep 6,799
I have an 18" track fitment for the G80/2/3 that might work on the M2s but it would be really aggressive on these cars: 18x10.5 ET18 square. We'll know more about what can and can't clear once we bring a few cars in for scans.
-Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
03-19-2023, 10:17 AM | #10 | |
Rep 1,200
Then speak to the dealer about getting a wheel/tire setup that you believe would be better for where you drive. Have to say my experience is while I have hit a pothole big enough/deep enough to ruin a run flat tire the wheel/suspension was fine. 'course, was with a MINI JCW not a M2. But I also have to point out that I hit that same pothole driving my Hellcat with its 20" wheels/tires and the larger diameter/wider wheel/tire rolled right over the pothole. Thus I was not aware of how bad it was until I hit it driving my JCW. Also, you can be a bit more sensible about when/where you chose to drive fast. Was in my Porsche 996 Turbo which I drove fast at times. I had to detour a bad accident on I40 west of Albuquerque. I ended up on a paved road that was more pothole than road. I slowed down and weaved around the potholes. Made it just fine. And anyone of those potholes would have meant doom for at least a tire... |
03-19-2023, 10:45 AM | #11 | |
Rep 3,033
When building an M2, no tire, rim or size options other than do you want the rims in all black or bi-color. |
04-03-2023, 05:46 PM | #12 |
Rep 261
I had a 2017 Alfa Giulia and broke a wheel in a pothole. It had 19" cast aluminum. I cannot imagine the M2 wheels will fare better if it is the right pothole.
Certainly if the M3/M4 can fit an 18 the M2 will be able to. It has the same subframe assembly and track. We also know it has the same brakes as the M3/M4. That said you will need to carefully check because not all 18's will fit, that's for sure.
2023 M2
2014 Triumph Trophy |
04-04-2023, 03:31 AM | #13 |
Rep 1,547
Not to hijack too much, I hope, but if anyone has G8x experience with SPECIFIC 19 square wheels good for winter potholes, I'd love to hear it. I'll need winter shoes for my M2.
On my E90 (RFTs, sigh) I first tried cheaper wheels, but they dented up pretty bad, so I finally settled on some BBSes that were robust. Of course, I can't use those since they are the dying 5x120 offset. So if anyone has had great success with a relatively affordable set of strong wheels, that info would be helpful to me. Looking tolerably nice and being rugged are the key goals, lower unsprung weight is just a bonus. Do any OEM wheels fit that bill? |
04-04-2023, 05:59 AM | #14 | |
Rep 148
04-04-2023, 04:30 PM | #15 | |
Rep 1,547
My understanding is that, for the M2, you probably can't drop below 19" on the fronts and still clear the brake assembly. And you want to use a square setup on winters (IMO) so you can move wheels around as needed. So 19 square seems to be the way to go. EDIT: To be clear, if someone DOES know about a specific 18 wheel that will fit on a G87, I'd love to know! Last edited by Squidget; 04-04-2023 at 04:40 PM.. |
04-05-2023, 07:32 AM | #16 | |
Rep 148
A 255/35/19 and a 255/35/18 have the same sidewall height of 3.5" APEX is a wheel vendor here that has a focus on BMW. They are very knowledgeable. APEX does fitments on vehicles soon after they become available, and it won't be long before they have fitment information on the M2. I would reach out to them and see what they have to say about a square 19 for the M2. |
04-05-2023, 11:35 AM | #17 |
Rep 1,547
Yes, that chart shows what I am trying to say. On the second setup, the wheel diameter has increased by an inch. I was taught that you should not alter that. Your ECU expects a specific wheel diameter, changing it screws with ABS, messes up your odometer, etc.
I was taught that the better way to increase sidewall is to keep the same tire diameter, and to reduce the wheel size. (And yes, means you have to figure out a new aspect ratio, because tire math is fun, whee) |
zero213262.00 |
04-05-2023, 11:59 AM | #18 |
Rep 1,547
Maybe this example will be more clear, this is how I was taught to increase sidewall for pothole resistance.
Start with the OEM size (285/30/20), then drop the wheel size (19), then play with the tire width and profile until your tire diameter is within a percent or so of the original OEM. In this case, I ended up with (275/35/19). That's a half a percent smaller diameter, which is considered OK. (285/35/19) also works but (for winter) narrower tires are considered better. |
zero213262.00 Chet for short203.50 |
04-07-2023, 01:47 AM | #19 | |
Rep 755
Squidget3533.50 |
04-07-2023, 02:44 AM | #20 | |
Rep 1,547
To others: My example downsized the G87's OEM rear tires. I didn't do the same example for the fronts, because the downsize resulted in 275/35R19, which is also the exact size of the G87's OEM FRONT tires. So I'd already come up with a single size that I could use for all 4 corners of the car. |
Rx-7ames1903.00 |
04-12-2023, 12:30 AM | #21 | |
Rep 13
Front- 275/40/18 (+0.4% diameter difference) REar - 275/40/18 ( exact match) Stock 9.5J front and 10.5J rear will have to be worked though. Question is will an 18" 9.5J wheel clear the brakes and have no issues with dust etc getting stuck between the brakes and wheel like some people reported with the 824M wheels. |
04-17-2023, 02:18 PM | #22 |
Rep 1,254
I have both the 18/19 824M combo and the 19/20 826M combo for my G80 M3. I much prefer the 18/19 setup for everyday use, and I actually think the car handles / steers better with the smaller setup.
