03-27-2023, 09:45 PM | #1 |
Rep 25
xHP has disabled my 2022 M240i
EDIT: This issue has been resolved. It turns out that the xHP Flashtool adapter that I received was defective, leading to dropped connections in the middle of the flash which disabled my car for a day. I was able to resolve without any intervention by the dealership with assistance from this thread as well as direct assistance from xHP Customer Support. If you wish to use xHP on a G-series BMW, I would recommend getting the MHD Uni Wifi Adapter instead of the blue official xHP Flashtool Adapter.
Good evening. I'll get right to it:
I tried for the next four hours to resolve the issue or even uninstall xHP. Each time it fails. I tried multiple Android phones. I tried configuring the static IP address, gateway, and subnet settings per the Troubleshooting guide. I even tried using a Windows 10 laptop. In all cases, I am able to connect and start flashing, but the flash will fail. Sometimes at 3%, sometimes at 85%. Same with uninstall. Car is immobilized. Sent support ticket to RBT (the creators of xHP) and included the logs from both my android and windows 10 attempts. Any thoughts? Greatly appreciate any assistance. Last edited by Zemzam; 03-31-2023 at 09:21 PM.. |
03-27-2023, 10:17 PM | #2 |
Rep 355
I used the MHD adapter and it required me to update the firmware on the adapter; does the ECS Tuning adapter support firmware updates? either way, I highly doubt the xHP app will start overwriting files without making sure everything is in line so that is a bit weird. hopefully you're able to get this resolved quickly
Zemzam41.50 Giovany_249.00 |
03-27-2023, 10:28 PM | #3 |
Rep 25
I am not aware that I can update the firmware to the xHP Flashtool. It might be the case. Ill check it out.
Oddly enough, I am not a stranger to xHP. I had it on my 2017 M240i. I loved it. But it is NOT playing nicely with my G42. |
03-28-2023, 01:55 AM | #4 |
Rep 433
No idea about the tool you are using, but when using BimmerCode, the car needs to be in Diagnostic mode (3 quick presses of the Start/Stop button), we’re you in this mode?
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
Zemzam41.50 |
03-28-2023, 02:48 AM | #5 |
Rep 25
Invisiblename355.00 |
03-28-2023, 04:55 AM | #6 | |
Rep 610
There are no firmware updates for the xhp adapter. My xhp flash using my iPhone failed the first time at 13% on the second stage. I just started the flash process again and it was successful. Do you have your battery hooked up to a charger? I know that the flash is pretty quick but maybe your battery is dipping a bit low and thus failing the flash. Whenever I flash xhp the initial time I always use a battery charger to be safe. Future flashes don’t need it as it takes less than a minute. Make sure lights, ac/heat, heated seats, all of that stuff is off as well. |
Zemzam41.50 |
03-28-2023, 06:48 AM | #7 | |
Rep 25
And yes, lights, AC/heat, heated seats all turned off. I even dimmed the dash lights. lol. |
03-28-2023, 08:01 AM | #8 |
Rep 1,559
I have nothing useful to offer, but am looking forward to the fix. I do remember having issues finding the right combination of settings (wifi, airplane mode, etc.) to establish the original connection with the iPhone, but once connected all went well.
Zemzam41.50 |
03-28-2023, 08:24 AM | #9 | |
Rep 25
I received a response from xHP, which is nice. I have included - for this forum - my answers in red. That way perhaps this thread can help someone else in the future:
I'll update as I get more info and hopefully get this resolved soon. Thanks for all the suggestions and support. Every little bit helps. |
XC3LLR82062.50 |
03-28-2023, 10:18 AM | #10 | |
Rep 1,559
Zemzam41.50 |
03-28-2023, 12:36 PM | #11 |
Rep 25
03-28-2023, 01:43 PM | #13 |
Rep 104
Sorry if Im late to the party, is this a flash tune? I thought mid 2020 BMW chsnged ECU to Bosch which are encrypted and can only unlock by sending to Finland
03-28-2023, 02:11 PM | #14 | |
Rep 25
...the transmission is controlled by a separate unit (same interface OBD) than the ECU. The TCU can still be flashed. That is what I am trying to do. xHP transformed my previous car, and it IS certified for this car. However at present I am experiencing technical difficulties |
03-29-2023, 07:22 AM | #15 |
Rep 25
Last night here are the steps that were taken:
I have tried two completely different Android devices that are otherwise in perfect order: • Google Pixel 6 with all updates installed (Android 13) • Oneplus Nord N10 5G (Android 12) @XC3LLR8: Because the Windows 10 Laptop succeeded in uninstalling - and thereby un-disabling my car - on the third try, I did not want to press my luck and try applying the tune with an iOS device yet. I will wait for the weekend to try that when I have more time to fix it if it also fails. I have tried with two different Wireless adapters using Windows 10 • Laptop:
With all those different hardware configurations, I was only able to successfully re-enable my vehicle after three tries with the Windows 10 PC. So, I have my car back, but do not yet have a successful tune. At this point I believe the issue may be one or two things: • Possibility #1: Android 12 & 13 do not like staying connected to WiFi devices with no internet connection while in Airplane mode. And/Or • Possibility #2: The xHP Flashtool that I purchased may be defective Those are the only two options that seem to explain how it can fail so consistently across multiple platforms. However, I could be completely wrong. I need to use the car for the next few days, but I will try again to apply the tune this weekend when I have more time to try repeatedly without interruption. As a precaution, I have ordered the MHD UNI Wi-Fi Adapter as a backup. It arrives tomorrow. If the xHP Flashtool really is defective, I want a separate device to confirm. Sorry for the VERY long response. Someday this might help someone else with the same issue, so I am trying to document. |
03-29-2023, 07:27 AM | #16 | |
Rep 25
FAST reply from xHP this morning:
03-29-2023, 11:47 AM | #18 |
Rep 25
03-29-2023, 12:54 PM | #20 |
Rep 1,559
We wouldn't have a space program, or literally any program, if every little glitch scared everyone off.
The product is great, so great in fact he's still willing to try it again simply because of how much he liked it in his previous car. If you're still hesitant just wait until he posts the fix, as the issues he experienced are very few and far between. |
Zemzam41.50 |
03-29-2023, 02:07 PM | #21 | |
Rep 25
I legitimately have no doubt that I will discover the solution. Even after things went about as bad as they could, I was up and running again within a day. All tuning and performance modification carries a degree of risk, but as far as risks go xHP is fairly mild and the return you get in terms of driving enjoyment is well worth it in my opinion. So I understand your apprehension. If you have a G42 generation of the M240ix and want to wait until I can provide more info this weekend, I totally understand. I just want to clarify that I am fully committed to installing the tune, I just need to figure out my connection issues. Previous F-chassis cars could use an eNet cable whereas at present the G series seem to prefer a wireless connection. There are countless individuals that have not had my issues, so I am certain this is just an extremely rare case. |
XC3LLR82062.50 |
03-29-2023, 02:37 PM | #22 |
Rep 19
I think your problem is directly related to the XHP wifi adapter, this adapter is a rebranded version of the MHD wifi orange adapter, which always had big connectivity issues, if there are wifi networks around your area that will be enough for the connection between the flash device and the adapter to drop, resulting in failed flashes. I highly recommend you purchase the MHD universal adapter (red color) and give it a try. I myself have flashed XHP with no issues on my G42 using that adapter, and have had 0 connectivity issues with it even with tons of wifi networks around. Just make sure to update the firmware of the adapter before trying to flash (download the MHD app for F+G series on your phone, plug in the adapter to your car's OBD2 port, connect to the adapter from your cellphone, open the app and read fault codes, the app will automatically update the firmware to the latest version).
Zemzam41.50 |
