03-30-2023, 06:02 PM | #2 |
Rep 375
I looked for that for a while only found the 2.0, but the wiring is going to likely be the same. These aren't model specific wire harness, so this is not a simple plug and play. Also is typical BMW fashion the kit doesn't even come with the electrical connectors you may need for all the different series. I was unable to determine the connectors with any certainty and based on the cost and then amounting of hacking. Decided a standard 12v dash cam is the way to go, cheaper, easier and better quality. Just not as integrated. I can't see the monitoring while parked working well with the car battery, for as large as it is, it drains quickly, especially if you don't drive it every day. If you want monitoring while parked an external dash cam battery would be the best option.
04-02-2023, 10:13 AM | #4 |
Rep 2,095
