Going into service tomorrow, should I have them upgrade software?
01-13-2009, 11:33 PM | #1 |
Rep 59
My car: 07 335 coupe
New turbos around June 08, this was the last time car was in for service. Just un-installed my JB2HR. Tomorrow the car is going to the dealer for a normal maintenance with oil change and brake fluid flush. I have read through all recent posts regarding the boost lag and wastegate issues with software flashes. Question: should I request that they upgrade all software or leave everything alone? Thanks! |
01-14-2009, 12:17 AM | #2 | |
Rep 1,948
My understanding is that they DO NOT UPGRADE ANYTHING unless there's a need to do it. I believe the DME upgrade takes 3-4 hrs anyways so they usually prefer the vehicle overnight. I may be wrong but I believe BMW works with the thinking, if it ain't broke, don't fix it.... or if the customer ain't bitchin', let them suffer
01-14-2009, 01:25 AM | #4 |
Rep 1,717
to answer the question i think youre getting at ................. yes, ask them to upgrade it
Formerly addicted to e46fanatics
Formerly addicted to e90post |
01-14-2009, 08:31 AM | #6 |
Rep 1,037
turbos replaced in june???? why? i tried to get my software updated yesterday for the lag bullshit and the guy told me the new progman won't do anything to help. buuuut he also told me that if i had a tune on my car and didnt tell them about it, when they hook it up to the machine it will show an error and immobilize the engine. hmmm, pretty sure that won't happen.
i'm not addicted to boost, but i sure am more fun when i'm on it.
01-14-2009, 08:44 AM | #7 | |
Rep 7,377
01-14-2009, 12:25 PM | #8 |
Rep 59
It was somewhat common for early 07 build 335 to need new turbos. I didn't own the car when they were replaced so I dont know the symptoms.
The car went in this morning. Head tech told me he wouldnt be upgrading the software unless it was completely needed (which its not). The check engine light came on this morning driving to the dealership, and the turbos were not turning on at all, the car had hardly any power. What could I have done on the un-install on the JB2 to cause this? I double checked my work, and did put back the boost solenoid. Hopefully when I reinstall the JB2 the problem will resolve itself. I just told the tech not to worry about the check engine, and he said that was fine. |
01-14-2009, 07:31 PM | #9 |
Rep 1,037
tell me about it. i have a boost guage but im stock for now and the guy kept tryin to like stare into my soul when he was tellin me about that. he was like "ARE YOU SURE YOU DONT HAVE A TUNE". i was like nope pretty sure, wanna take a look?
01-14-2009, 07:55 PM | #10 |
Rep 2,760
I have a boost gauge too, and been to a few dealers with it (never bothered take it out) both with the Dinan tune and stock. No one ever said a word to me. Boost gauge is harmless but I suppose it depends on dealer whether they hassle you or not. In the end, they can't really do anything about it. Its not proof of anything other than a boost-gauge ofcourse. Oh, and I have aftermarket wheels too.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
01-14-2009, 07:56 PM | #11 | |
ocasionally in crisis
52
Rep 2,358
your can has no power after un installing the JB and you brought your car into the dealer that way ?? if the answer to my above question is yes, then my response to you is: SHIT MAN, WHAT ARE YOU DOING ON THIS FORUM?? EMAIL TERRY right NOW via the other forum and find out all you can. if you uninstalled the JB wrong and the BMW tech finds traces of a piggyback install, your warranty can be immediately voided. my 2 cents
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / Last edited by midlife; 01-14-2009 at 08:18 PM.. |
01-14-2009, 08:41 PM | #12 | |
Rep 310
01-14-2009, 08:52 PM | #13 |
Rep 2,808
01-14-2009, 09:12 PM | #14 | |
52
Rep 2,358
then i would ask terry what was wrong.
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
01-14-2009, 09:14 PM | #15 |
52
Rep 2,358
hopefully the tech is an idiot and will ignore the check engine as the OP requested.
or maybe the tech is smart and reported this to the service mgr. asking a BMW tech at a dealer to ignore a check engine light seems to be a lot more than a bit suspicious
01-14-2009, 10:44 PM | #17 | |
Rep 2,808
Next time he should try this, and see what happens: "Ummm...yeah, so if you spot a broken tmap sensor clip thingy, don't worry about it, and just move on, ok?" Ok... I'll stop bugging him! |
01-15-2009, 09:00 PM | #19 |
52
Rep 2,358
i honestly hope he does not have warranty issues because of this.
i wish him luck...even though he is asking for it in some ways
