BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) How to Repair Minor Scratch Advice
      04-04-2023, 11:33 PM   #1
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
Hi,
Need help repairing a minor scratch on the front of my G80. Attaching an image. I tried a clay bar and that didn’t do anything. There is a part that’s chipped but I’ve ordered paint for that already, not sure what to do for the other part of the damage. Any advice is appreciated.
Thanks!
      04-05-2023, 12:00 AM   #2
diablo2112
2024 M440i GC (G26)
286
Drives: 2024 M440i Gran Coupe
Dr. Color Chip
      04-05-2023, 12:03 AM   #3
wavyyyy
Drives: M2C
Originally Posted by diablo2112 View Post
Dr. Color Chip
Part of it is chipped however there’s also the line going across that isn’t a scratch but appears to be something on the surface. Used elbow grease already and it didn’t work.
      04-05-2023, 01:39 AM   #4
diablo2112
2024 M440i GC (G26)
286
It may be a scratch in the clear coat only. First, try a clay bar + detailer. If that doesn't polish it out, then consider using the Dr. Color Chip technique with BMW sourced clear. The BMW touch up paints come with 2 bottles: color and clear. I'd use color in the chip (using the Dr. Color Chip method: apply next to chip, use squeege to smooth over the chip, let dry 3-5 minutes, then use blend solution to gently dissolve and blend excess paint around the chip. Repeat this with clear on the clear-scratched portion.
wavyyyy1070.00
      04-08-2023, 07:09 PM   #5
Alekss
Alekss's Avatar
9
Drives: BMW 328i xdrive
It is really hard to tell without looking at it in person.
Clay bar does not repair scratches. Clay bar will remove surface contaminants which a regular wash otherwise would not. However, you can use clay to remove paint transfer, which at first may look like a scratch.
Since you have a chip followed by a scratch, the biggest question is, how deep is the scratch? The paint chip is likely deep enough such that it is through your clear coat and into the base coat, maybe even down to substrate. There is nothing you can do here other than touch-up paint. As far as the rest of the scratch goes, you can locally paint correct this area. Again, depending on the depth of the scratch, the paint correction technique will remove or reduce the appearance of the scratch.
      04-10-2023, 07:49 AM   #6
Chad11491
Drives: 21 IOMG M3 6MT
my "rule of thumb" is that if you can feel the scratch with your fingernail, no amount of polishing will fix it. If you CAN'T feel it, and you don't have a polisher on hand, try getting some Griot's fast correcting cream compound, a microfiber rag, and put some elbow grease into it. It should come out. Otherwise it will probably require paint touchup like mentioned above.
      04-10-2023, 05:08 PM   #7
TboneS54
YNWA
TboneS54's Avatar
Drives: '04 M3 6MT, '11 M3 DCT, '22 X7
Probably a combo of both. In these situations, I like to apply a little Dr. color chip (to the worst part, actual base or metal showing), then come around a day or more later and buff it by machine with a regular polish and poishing pad, not compound and dense foam or MF pad, so as not to remove much of the Dr. Color chip, have it look natural and high polished which makes the scratch or the part of the scratch that didn't penetrate the base coat, look invisible.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
wavyyyy1070.00
