04-07-2023, 08:25 PM | #1 |
Rep 778
wheel spacers
What’s everyone’s opinion on what you think will be the best size for a good flush fit taking into account the car will be lowered (not slammed)? 12mmR/15mmF maybe?
04-07-2023, 10:14 PM | #2 | |
Rep 1,843
Edit: I have to amend this opinion after seeing companies going with up to 15/18 after lowering. Apparently there is serious gap from the factory. Last edited by zero21; 04-25-2023 at 07:44 PM.. |
04-07-2023, 11:06 PM | #3 |
Rep 778
Guess because I was comparing it to what I have on my M240i (which I know isn’t exactly an apples to apples comparison). I’m currently using 10-12mm on that and it’s just about right but could poke a touch more imo. My G87 isn’t showing up until mid to late May so I’ll check to see what the first deliveries are gonna do with spacers and see how they look to give me a better idea. Are you doing spacers when you switch the wheels out?
04-07-2023, 11:48 PM | #4 |
Rep 3,035
What spacer you may, or may not, need depends on your rims. The spacers needed if staying stock or getting aftermarket rims with the same exact size/offset would be different than if you get aftermarket rims with different offsets which may cause the need for different sized spacers or eliminate the need for spacers altogether.
04-08-2023, 05:39 AM | #5 | |
Rep 1,843
04-08-2023, 07:23 AM | #6 | |
Rep 778
04-08-2023, 10:30 PM | #7 |
Rep 1,012
04-09-2023, 01:49 PM | #8 |
this is the way
18379
Rep 8,571
Any reputable dealer that sells wheels should be able to tell you what offsets you can run on stock setup without rubbing. May take a while for them to figure that out, they'll need an M2 to test it on. If you have spacers already in different sizes, you can do some trial and error yourself until you find what works best.
Another thing to consider is if you lower the car, you'll need less positive offset than if you were at stock ride height. |
M_Power Rob3763.00 Mike_H_264.50 |
04-10-2023, 11:56 PM | #9 |
7433
Rep 10,239
IND will more than likely give us a side by side breakdown of different widths soon enough.
IND-Distribution9599.00 zero213262.00 |
04-11-2023, 12:03 AM | #10 | |
Rep 1,012
04-12-2023, 07:21 PM | #11 |
Not great. Not terrible
7448
Rep 2,700
Fortunately the wheels I have coming from Richland Forged should provide me 12mm poke in the front and 15mm poke in the rear. Even without a drop, based on the photos from IND, that should provide a much better stance. It'll be further enhanced by HAS.
Current: 2024 BMW X3 M40i.
04-12-2023, 07:32 PM | #12 | |
Rep 1,012
Found it https://www.bimmerpost.com/forums/sh...php?p=30028295 |
IND-Distribution9599.00 |
04-12-2023, 07:34 PM | #13 | |
7448
Rep 2,700
Looking forward to seeing how it looks with everything else stock before doing HAS and such.
04-12-2023, 07:36 PM | #14 |
Rep 1,012
I think I'm aiming for an extra 12 poke up front and 10 in the back. With HAS port installed and 10-15 mm drop I think it will sit well.
04-12-2023, 07:39 PM | #15 | |
7448
Rep 2,700
I have some carbon bits coming from RW Carbon. I feel the ZB needs a little contrast to break up all the blue.
sl0m01296.00 |
04-12-2023, 07:42 PM | #16 |
Rep 1,012
I was going to use black on the roof and a few other spots, but I'm all in on CF now. I am getting the decal that is in this photo to break up all of the blue on the side.
JustinHEMI7448.00 |
04-12-2023, 07:44 PM | #17 |
7448
Rep 2,700
I like that! After seeing the decal on Zero's car, I liked how it broke up the blue, and am on the hunt for a decal. That one will go on the list of possibilities.
sl0m01296.00 |
04-12-2023, 07:47 PM | #18 | |
Rep 1,012
JustinHEMI7448.00 |
04-12-2023, 08:03 PM | #19 | |
Rep 1,843
Plus it's worth at least 5hp |
04-13-2023, 11:51 AM | #22 |
Rep 284
I added 10mm front and 13mm rear to mine last evening. Can def take more
JustinHEMI7448.00 StickyPickle1592.00 Squidget3533.50 Game7432.50 johnnie311197.50 ledgy189.00 T_U_D6687.00 billspreston337.00 |
