04-08-2023, 04:20 AM | #1 |
Rep 6
Fitment question
Hey all, I have a RWD 2016 M235i wanted to know if it's possible to run 19x8.5 ET32 squared. More concerned with rear fitment as I have read that someone was able to run this setup in front with no problem, although rear fitment was not mentioned.
Currently on stock suspension, considering dinan springs. Any help would be much appreciated. |
04-08-2023, 01:35 PM | #2 |
Rep 1,022
I'd be concerned about fender rubbing in the front as well TBH. Might be OK with 225s, but probably not anything wider.
04-09-2023, 04:09 PM | #3 |
Rep 6
04-09-2023, 08:12 PM | #4 |
Rep 1,022
Most people upgrading wheels/tires are looking to get more rubber on the road, in either square or staggered configurations. If you are more concerned about maximizing poke 225s on ET in the lower 30s will probably work.
04-11-2023, 12:47 AM | #5 | |
Rep 6
Is there any tire setup I can run that would not require a stretched tire setup. And if so, what modifications would need to be made in order to accommodate said setup. |
04-11-2023, 09:53 AM | #6 | |
Car Geek
3727
Rep 3,632
At the rear the 245 wide tyre will probably be about 5mm outside the fender with ET32 vs ET52 stock, but will probably clear the lip on full compression, if not a fender roll/stretch could create clearance or alternatively adjusting the rear suspension to say -2.1 compared with the stock -1.75 using the stock eccentric bolts may give enough clearance. |
