04-09-2023, 05:09 AM | #1 |
Rep 87
Drives: 2014 335i Xdrive
Lowering Springs Eibach or HR
Looking to close the wheel gap on my f30 335 xdrive. Heard going too low on xdrive can cause front axle issues.
Debating between: Eibach pro kit springs H R Sport springs What should I go with keeping in mind the xdrive issue |
04-09-2023, 08:09 AM | #2 |
Rep 4,380
https://www.eibachshop.com/
Eibach Pro-Kit has different front and rear springs for all the different models/trims/engines based on weight over the front and rear axles, has the most comfortable ride, since the spring rates are just 10% stiffer than stock and most importantly addresses reverse rake, by lowering the front more than the rear. other brands offerings are just rwd or x-drive, stiffer riding and most do not address reverse rake, so front wheel gaps will appear slightly greater than the rear. . Last edited by alohasurftoad; 04-09-2023 at 11:00 AM.. |
