04-10-2023, 07:31 AM | #1 |
Rep 12
F30 springs on a F33
Good day everyone
I hope everyone is good I just joined today and hoping to get some wisdom. I have a 2015 BMW F30 320i M-sport and a G20 330i M-sport The F30 currently has H&R lowering springs (Low 28877-2) I'm currently in the process of changing my F30 for a F33 420i M-sport, I've always wanted a convertible. Both cars don't have adaptable suspension Could i use the F30 springs on the F33? |
04-10-2023, 10:42 AM | #2 |
Rep 4,380
can you = yes
should you = no I recommend springs designed for a F33 since is much heavier(especially in the rear) than a F30 |
04-11-2023, 12:30 AM | #4 |
Rep 12
Thank you so much for the feedback
Much appreciated |
alohasurftoad3130.50 |
04-11-2023, 01:55 AM | #5 |
Rep 4,380
if available in south africa, i recommend you consider eibach pro-kit as it has more comfortable ride than h&r and it also addresses the reverse rake, fixes issue of front wheel gap being larger than the rear wheel gap.
Eibach Pro-Kit, E10-20-031-07-22 https://www.eibachshop.com/index.php...-4-convertible |
ooovie3.00 |
04-11-2023, 02:39 AM | #6 |
Rep 12
Thanks for that, the only reason I went with H&R at the time was because it was the lowest spring i could find because I didn't want to go the coilover route. I was actually surprised of how small the difference was in ride quality.
You not the 1st person to to me about Eibach, i will see the options they have. Thanks so much |
04-11-2023, 03:11 AM | #7 | |
Rep 4,380
ooovie3.00 |
