335xi '07 n54 no crank no start
04-16-2023, 09:34 PM | #1 |
Rep 4
I've spent the past two days attempting to fix my bmw and so far have had no luck.
Title says it but heres what ive tried: New starter - Works when out of car New battery Measured alt and its normal Measured b+ cable and its delivering power Made sure engine block ground is grounded Engine will turn over manually so its not seized Spark & fuel & compression is fine Jumped battery while attempting to start What im hearing, Starter is clicking, along with a click on the driver side uppermost corner and some humming List of codes ive pulled from MHD(I have tuned to stock map & stage 1+ to see if it would make a difference, it didnt), that are important, some codes i expect due to certain things not being plugged in. 2E7C BSD bus communication fault. 2AB4 DME: DME, internal fault: ram checksum(thinking of replacing dme?) 2D5F Reset (inactive code) Any help would be appreciated, i have spent a lot of time looking and talking with friends and I have nothing left that I can think of. |
04-16-2023, 10:05 PM | #2 |
Rep 2,015
Ground Strap on Drivers Side, did you check that, attach a jumper cable ....short one, from 1 end to the other.
Other than that, take it to dealer and tell them what you have done already. They can pin point an issue as they have an in-between computer with harness from DME to vehicle. This should only be an hour labor cost at dealer. |
gak0.00 |
04-18-2023, 11:15 AM | #3 | |
Rep 4
04-18-2023, 06:52 PM | #4 | ||
Rep 4,108
2) Please also indicate ALL Fault Codes, particularly any CAS Fault Codes, such as "A0B4" 3) Please indicate what Scan Tool or Diagnostic Software (INPA/ISTA) you have available to read fault codes in Modules OTHER than DME. 4) Please indicate if your transmission is AT or MT. George |
04-18-2023, 10:32 PM | #5 | |
Rep 4
The only codes that I have pulled other than mentioned was a consistant lean ratio(29E1, 2A2C) 2ABC, 3100 and a turbo charger high voltage code I cannot remeber the exact one, but i believe it was because I had sensors unplugged. I have no other code readers other than a handheld generic one, which is where i got the lean code from other than the dme. Automatic transmission |
04-22-2023, 04:00 PM | #6 |
Rep 4
So far ive found this: The Engine is fine air fuel compression all okay, the engine ground strap is fucked(?) so ive orderd a replacement strap. The only issue im having with this is its reading 3-5 volts Below head gasket, 12 above head gaskets on the block but perodically also measuring 3-5 above them aswell. Strap is green and frayed to hell so ill update if that was it when it arives.
04-26-2023, 08:34 AM | #7 |
Rep 2,015
Look up Vanos Cleaning and reinstalling....but when reinstalling, swap them.
I read that P3100 is Vanos related in these cars which would make it run lean possibly. see this threat.....and google P3100 on bmw. and you can make a Ground strap yourself....Just use a Good 4 Gauge wire with proper soldered endings. https://www.e90post.com/forums/showthread.php?t=645623 |
