BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions G30 headlight switch replacement “How To”
      04-19-2023, 04:24 PM   #1
Mik3ymomo
Mik3ymomo's Avatar
206
Drives: 540i XDrive
As many of you know there is a service bulletin for the headlight switch. After taking it to my local dealer and telling them what it was they charged me $277 to diagnose it and then wanted another $770 to replace it.
I am not new to working on cars so I decided to do it myself and took photos so I can provide instructions to do this yourself in 5 mins with simple tools.
If your headlight switch looks like this then you are in the right place. If your lights turn on and off during the day then this is your problem and the part is only $165 from Rock Auto.
I used a nylon pry tool to remove the side trim and it exposes one screw that you can remove or move out of the way the vent above the headlight switch.
The switch will come right out with only the plug attached to the back. It unplugs by just pulling on the plug.
Now plug in the new switch and reverse the process. I slightly pulled back the weatherstripping on the door to work the side panel back in.
You could probably reach your hand in behind the light switch without removing the vent but it’s just one screw and it’s a T7 Torx size. If you dont have Torx just reach your hand in the hole and push out the light switch from behind after removing the side panel.
admranger2984.50
      04-19-2023, 04:26 PM   #2
Mik3ymomo
Mik3ymomo's Avatar
206
Drives: 540i XDrive
Some more photos for you guys.
AwesomeM31644.00
admranger2984.50
maDjzo872.00
      04-19-2023, 04:45 PM   #3
AwesomeM3
AwesomeM3's Avatar
Drives: F95 X5MC
2015 BMW X5 M  [10.00]
2020 BMW X5M Compet ...  [0.00]
2008 M3  [10.00]
Nice work Mike!
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
Mik3ymomo205.50
      05-03-2023, 08:23 AM   #4
seis1
Drives: BMW g31
Thanks for the detailed pictures and description!
Mik3ymomo205.50
      09-27-2023, 07:55 PM   #5
jsf721
Drives: 2019 540i X M Sport
So what did you buy at rock auto and what did you replace ?
      10-26-2023, 02:40 AM   #6
Alscoob
Alscoob's Avatar
Drives: G31 540i M Sport Edition
Now plug in the new switchand reverse the process.
      10-26-2023, 07:25 AM   #7
DrSteveB
Drives: '18 540d, '18 X3, '10 335d
Please tell me the problem with the lights that led you to this solution? (excellent description of fix -thanks)
      10-26-2023, 07:52 AM   #8
tjbuggy2b
Drives: 2018 540i xDrive M Sport
He mentioned it in the OP but what happens is (during the day) the lights turn on for a second or two, then back off over and over. Mine is starting to do it. At the moment, I just have to turn the switch full left, then full right, and back to auto and it will behave for a while. Right now, I see it about once a month. I know this fix is in my future, though.
5post
