04-20-2023, 11:04 AM | #1 |
BMW obsessed
9599
Rep 10,891
IND | Fall-Line Motorsports G87 M2 Front Monoball Conversion
MADE IN THE USA. Fall Line’s monoball spherical bearing conversion kit transforms the front steering and suspension feel of the G87 M2. The factory rubber bushing is very large, and is prone to substantial deflection under load, as the car is put through its paces. Deflection of the bushing can create unwanted geometry change, steering wobble under braking, and even hysteresis of the thrust arm. The bearing’s housing is precision machined from aluminum, to create a rigid part that allows for the G87 M2 thrust arm to move smoothly through its range of suspension travel. The improvement in steering and suspension feel is immediate and truly enhances the personality of the new G8x. Product Details:
The Fall-Line Motorsports G87 M2 Front Monoball Conversion may be viewed at the following link to our online store: https://ind-distribution.com/product...all-conversion
04-28-2023, 01:16 PM | #3 | |
Rep 1,547
Will they void your warranty? Depends on a lot of things. I mean, if the monoball actually causes a failure, then HELL YES 100% they will void it. If the failure is unrelated... well they may still try to void the warranty, but you can fight that legally, if you want to. Gets messy. |
ourlee921.50 |
04-29-2023, 12:36 PM | #4 | |
Rep 862
Squidget3535.00 |
