What does this warning light mean?
01-15-2009, 07:08 PM | #1 |
Rep 1,149
I never got the manual so dont tell me to RTFM lol. Im guessing its a fluid. Can i refill it myself or i gotta take it to the dealer?
01-15-2009, 07:21 PM | #2 |
Rep 1,174
Your coolant level is low. There is a manual available on this forum for download.
01-15-2009, 07:24 PM | #4 |
Rep 1,174
01-15-2009, 07:25 PM | #5 |
Rep 230
Drives: '08 e92 335i
Location: little place called none of your Goddamn business
looks like radiator fluid to me. Check the manual, but if it is you can do it yourself if you know what you're doing. Do NOT attempt it on a warm engine. A friend of mine got 3rd degree burns from opening the radiator cap on his truck and the steam coming out burned the sh** out of his hand.
Basically make sure you know what you're doing (both in terms of coolant you use, getting a perfect 50/50 water dilution, and the actual replacement).
2008 335i | Space Gray | Blk & Gray Poplar | 6 MT, M3 Lip, Painted Reflectors, Huper Optik 30 (35%), V1 Hardwire, Pussy Magnet
01-15-2009, 10:19 PM | #12 |
Rep 8,745
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
01-15-2009, 10:42 PM | #13 |
Rep 1,369
01-15-2009, 10:59 PM | #14 |
Rep 2,409
01-15-2009, 11:12 PM | #15 |
Rep 1,149
Cant.. got an intake and a juicebox in the engine. Don't feel like taking it out. By the way i forgot to mention when i turned the car off and turned it back on the light went away. This happened last night too. Can i just add water?
01-16-2009, 11:25 AM | #17 |
Rep 2,548
01-16-2009, 12:27 PM | #20 |
Trance Life
315
Rep 4,706
Bro..I went through this exact same thing last month.
Go to your nearest BMW dealer. Pick up some BMW brand coolant. Go to the supermarket, buy some distilled water. Mix the coolant and distilled water at a 50:50 ratio (use a measuring cup to be precise). Mix the solution. Pour it into the reservoir until the needle starts to bob about an inch out of the reservoir. You're done. |
01-16-2009, 12:56 PM | #21 |
829
Rep 3,982
Don't use a different type of coolant. And unless you live in Alaska and its -20 degrees, just top it off with distilled water and you will be good. Remember, too much coolant will actually dissapate LESS heat. FYI: many race cars use little or no coolant at all.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
01-16-2009, 02:16 PM | #22 | |
Trance Life
315
Rep 4,706
