04-25-2023, 08:06 AM | #1 |
Armchair Aristocrat
338
Rep 444
SPL Parts vs VAC lower control arms
If I've lowered my car 1" via Dinan springs, should I get SPL Parts control arms for roll center correction (kern417 seems to prefer this) or is it ok to get VAC control arms with no roll center correction but which was created for stock suspension geometry?
04-27-2023, 11:28 AM | #3 |
Rep 3,549
In order to properly do roll center correction, ALL of the arms (tension strut, LCA, and tie rods) need to have that adjustment. It doesn't help if only one of the arms has it.
Also, if you're going to do it, you should really have a center of gravity measurement done to see how much correction is really needed.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
Jvac438.00 |
04-27-2023, 05:27 PM | #5 |
Rep 383
04-27-2023, 11:57 PM | #6 |
PdV Motorsports
121
Rep 165
Drives: 2014 335i xDrive sedan
Measuring it is one thing and perhaps you mean measuring it before and after though that is highly predictable. I'm curious if you'll expand on why and how you use that info to determine how much RC lowering is needed and how you get there when you can not control the front strut mounting point or angle without a custom upright.
Ryan M. PdVMotorsports.com Owner https://www.youtube.com/@pdvmotorsports
2014 EB M-Sport 335i xDrive - PdV/BC custom coilovers, PdV spherical rear shock mounts, PdV big brake kit, MHD Stage 2+ Next up: PdV genuine GTX3582R Gen2 turbo kit, Nostrum HPFP & Stage 2 injectors, PdV PM5 w/ "Veyron" Bosch E5LM |
04-28-2023, 11:08 AM | #7 |
Rep 710
As someone who litetally just had the vac monoball thrust arms removed because of NVH with dinan springs and shockware… i’d say to just leave your bushings stock unless you live in an area with absolutely perfectly paved roads.
