BIMMERPOST Universal Forums General BMW News and Cars Discussion BMW M Will Make Electric Cars Feel Like They're Powered By 1,000-HP Combustion Engine
      04-27-2023, 12:03 PM   #1
Tag
this is the way
Tag's Avatar
20223
Drives: N-1 starfighter
Post BMW M Will Make Electric Cars Feel Like They're Powered By 1,000-HP Combustion Engine
BMW M Will Make Electric Cars Feel Like They're Powered By 1,000-HP Combustion Engines
APR. 27, 2023 7:45 AM ET / BY ROGER BIERMANN IN ELECTRIC VEHICLES
Want to make your electric M car build power like a naturally-aspirated V8? BMW will let you
do just that.
BMW may have solved the problem of electric performance cars that feel dull to drive, thanks to the
massive wave of unrelenting torque. In a patent filed with the United States Patent and Trademark Office,
discovered by CarBuzz, BMW proposes a system that would let drivers tailor various drivetrain
properties, including throttle mapping and torque delivery, going so far as allowing you to customize your
car's acceleration curve.
This new system goes beyond just predetermined driving modes as you'd find in any current car, where
Sport mode sharpens throttle mapping by 20-30% while Eco mode dulls responses by a similar amount.
Instead, BMW envisions a graph where you can create custom torque curves and throttle maps that
correlate to your speed, where each point in the curve can be tailored as you would your sound system
via an audio equalizer.
How It Works
Because electric motors don't rely upon momentum in the same way as combustion engines, they can be
modulated by various programming protocols, creating infinitely variable conditions. BMW thinks the
concept of predetermined driving modes is boring in the context of an EV.
The basic principle of the design hinges around two graphs or curves: a speed curve and an acceleration
curve. Both directly relate to the throttle, or gas pedal, position.
In the primary speed curve, the vehicle's speed is directly correlated to the position of the throttle. As
EVs primarily rely on single-speed direct drive transmissions, you can set a speed based on the position
of the gas pedal - or the use of a joystick-style control, as per the patent. You can choose from presets
with a linear map, a curved map, or an exponential graph and tailor an exact speed to a certain input.
So at 10% throttle use, you can always travel at 20 mph, while at 50% throttle, the car will drive at an
exact speed of 80 mph (or whatever other speed you select).
The acceleration curve is much more like the standard throttle map we're used to, where throttle input
correlates to how much more torque is applied. Prod the throttle 80% of the way down, and you prompt
80% acceleration, building speed continuously rather than capping speed based on the throttle pedal position.
Both of these curves can be tailored independently through inputs on the touchscreen, where a user can
drag certain points of these graphs up or down. In this way, you can choose to limit the car's top speed
using the speed curve or limit how strong the acceleration is at full throttle. Likewise, you can set the
throttle to be very twitchy at low inputs and stable at high inputs, or vice versa - smooth at the top of its
travel and sharp under heavy load.
Curves That Act Independently Or In Tandem
These curves can act independently or be combined to create an infinite array of throttle maps. If, for
instance, you map the speed curve in a particular way where 10% throttle increments result in 10 mph
speed gains, you can always know how fast the car will go based on your throttle position. 50% throttle,
for example, would result in a steady speed of 50 mph in this example. But you can then combine this
with an aggressive acceleration curve. Push the pedal for 0-50% slowly, and the car will gradually
accelerate to 50 mph. Go from 0-50% throttle quickly, however, and the car will accelerate to 50 mph
rapidly and then stay there. Alternatively, if you have a hyper-aggressive acceleration map, the car will
accelerate rapidly to correlate with your throttle position.
Compounding the technology further, the computer systems will be able to read how long your throttle
inputs have been in a steady state and adjust the acceleration curve. If you've been traveling at 60 mph
with the throttle at 60% for the last four seconds, you're likely traveling on a freeway and aren't going to
try to accelerate abruptly. So even if you have a sharp acceleration curve active, the system will dull the
initial responses to smooth out the drive.
But you are fully in control of every one of these graphs, so you can decide how the car responds to your
inputs. Like a car with a hair-trigger throttle? You can have it. Want something that accelerates smoothly
for easy traffic driving? You've got it.
The sounds of the car - like the Hans Zimmer-developed soundscapes in the BMW i7 - will also adjust to
these maps, so you can use auditory inputs to help you drive the car using your senses.
Making EVs Feel More Like ICE Performance Cars
While there are multiple benefits of this system, BMW specifically envisions it being used for
enthusiastic driving. The patent documents say, "Use can be made with the invention of the whole spectrum of
possible acceleration curves. The curve (shapes) can have an emotional character and delight the vehicle user."
Basically, you can tailor the driving experience to provide excitement through a building torque curve
rather than the on/off mentality most EV manufacturers use. Instead of linear acceleration - which is fun
at first but wears off as a novelty very quickly - you can have exponential acceleration curves that let
power and speed build proportionately to a number of inputs. Using this, your EV can mimic the behavior
of an ICE-powered car - and you can choose a graph that mimics the feel of natural aspiration,
turbocharging, or even supercharging.
The direct correlation between speed and throttle position is also helpful when driving on a track. BMW M
boss, Frank van Meel, told CarBuzz last year that one of the toughest elements of driving an electric M
car on track would be that drivers could not rely on sound and knowing what gear they are in to
determine their speed in corners accurately. But with this system, you can judge your speed more
accurately based on your pedal position.
By combining this sport of methodology with other EV-related patents like an active differential for electric
M cars
, BMW will make driving an EV more involving, adding layers of interaction that make driving an
EV exciting. As exciting as a combustion M car like the BMW M2? Perhaps not, but we can't say for sure
until that day arrives, and when it does, it'll likely be behind the wheel of the 1,300-hp electric M3 BMW is
developing
Massive Safety Benefits Too
But in addition to the enjoyable benefits for driving enthusiasts, there are also safety benefits. Parents, for
example, can limit the top speed of their child's car or even set and lock a more gradual acceleration
profile, preventing rapid acceleration that may prompt a loss of control.
A big concern with EVs that so easily put hundreds of horsepower in the hands of novice drivers for just
$30,000 is that these cars have too much power for the ordinary driver, and the on/off way in which they
are capable of delivering this power means that inexperienced drivers are at risk of hurting themselves
and others around them by not knowing how to modulate throttle inputs correctly.
By programming a so-called 'lazy' acceleration map and pairing this with speed correlating to
throttle position, 1,000-hp EVs could be as docile to drive as a BMW X1.
BMW will also make sure that the customized maps do not allow sudden changes that are too vicious,
adding another safety net.
Source: CarBuzz
FrozenGT1415.00
Patton2502948.00
M3 boi3224.00
      04-27-2023, 12:20 PM   #2
FrozenGT
FrozenGT's Avatar
1415
Drives: 2021 Z4 M40i - Lexus NX300 F
Oh wow!
      04-27-2023, 12:49 PM   #3
Patton250
Patton250's Avatar
2948
Drives: BMW X3,M5,Turbo S
Regardless, that car looks awesome. From all sides.
      04-27-2023, 12:54 PM   #4
br438
Infinite Boulder Roller
602
Drives: 2020 Ford Raptor
Yep. Electric performance vehicles (EPV?) will continue to become incredibly exciting to drive.
Will I like driving a custom mapped M3 better? ... or a custom mapped 3 m40e? maybe, but it will absolutely not be the same emotion that is cultivated by half of a century of riding/driving around in cars that have rapid-fire "explosions" thousands of times a minute 7 feet away from my body.
      04-27-2023, 03:02 PM   #5
Germanauto
Germanauto's Avatar
Drives: Alfa Romeo Giulia, Rosso
Cool idea but I wish with e-fuel exemptions, BMW M could still produce at least one ICE car in the future.
Former
-2008 E90 328 black/brown
-2012 Lexus IS250 black/black
      04-28-2023, 06:14 AM   #6
murderspice
Drives: 2018 BMW M2
This sounds like the software in the new demon 170.
      04-28-2023, 08:50 AM   #7
Marcoose
Marcoose's Avatar
Drives: 2016 sDrive35is
In before efftwentynineandahalf bitches again about mining pollution and socialism.
That car is effing brilliant.
      04-28-2023, 09:21 AM   #8
Theruleslawyer
Theruleslawyer's Avatar
Drives: 2019 m4
It is a cool idea along with the fake shifters that they are working on for EVs. The issue is that EVs are still very heavy cars. I don't know that EVs will have the power density to replace ICE for enthusiasts or people who track anytime soon. It'll probably be great for the guy who just wants a fast car and thinks that going through a cloverleaf intersection fast is sporty.
      04-28-2023, 02:38 PM   #9
G30M
G30M's Avatar
5497
umm ... Tesla already done that?
