F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > WOT on xDrive - Front lifts up?
Extreme Powerhouse
      05-08-2023, 04:39 PM   #1
Prak903
Prak903's Avatar
198
Drives: 2018 440i xDrive Gran Coupe
Hey guys, have an xdrive 440i. Was messing around with xHP and flashed some changes last week. Ever since then when going WOT from a roll/dig it almost feels like the power is going straight to the rear wheels, the front wheels almost feel like they are slightly off ground (steering gets looser). I'm assuming that flashing again reset the transmission adaptations, but I've never felt this before when going WOT. Any ideas, or is this just how it should feel?
TIA!
      05-11-2023, 08:45 AM   #2
Skyhigh
Skyhigh's Avatar
1900
Drives: BMW F36
xHP does not affect the xDrive in any way.... The TCU of the xDrive is a completely independent unit and software.
You may have affected traction in general with xHP... that's possible, bot not the characteristics of xDrive, in terms of distribution...
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
visionaut1316.00
Prak903198.00
      05-11-2023, 12:48 PM   #3
Prak903
Prak903's Avatar
198
Thanks Skyhigh. Maybe I had too much torque from launches and caused the rear wheels to slip, hence would activate front wheels for slip situation.
      05-11-2023, 12:50 PM   #4
Skyhigh
Skyhigh's Avatar
1900
Drives: BMW F36
During hard acceleration, it is normal to feel less weight on the front wheels and steering… simply because there is less weight on the front axle
Prak903198.00
      05-18-2023, 07:11 AM   #5
lattwood
Drives: BMW 435ix
Check your front dampers for wear, when this started happening to me shortly afterwards a front damper started to leak.
f30post
