05-12-2023, 04:13 PM | #1 |
BMW obsessed
9599
Rep 10,891
IND | G87 M2 Wheel Spacer Recommendations
With the release of the new G87 M2, we wanted to reduce the amount of guess work and time looking at countless threads to see what spacer sizing is recommended, so we set out to create a comprehensive resource.
Spacers are similar to aftermarket wheels with regard to opinions; everyone has different preferences and tolerances. We prefer the more subtle look with zero-wheel poke - our favorite setup on the new G87 is similar to our G8X fitment: a 15mm front and 12mm rear spacer set. Factory (OE Suspension /No Spacers) Recommend Spacer Sizing • Standard Fitment - 15mm Front / 12mm Rear • Aggressive Fitment - 18mm Front / 15mm Rear Bolt Patter and Thread Pitch / Sizing • 5x112 bolt pattern • M14x1.25 Future Classic 5x112 Wheel Spacers (Made in USA) • Complete kit includes: two competition wheel spacers, ten extended length zinc plated lug bolts, four hub bolts, Copaslip copper anti-seize, and an anti-seize applicator brush • CNC precision machined from 6061-T6 aerospace aluminum • Black anodized finish for corrosion and wear resistance • Provisions to secure spacer to hub for competition use • Hubcentric design with chamfered edges • Pocketed detailing for minimum mass Recommended Fitment: 15mm Front and 12mm Rear All Front and Rear Fitments: 5mm Front and Rear 12mm Front and Rear 15mm Front and Rear 18mm Front and Rear
23
Albator_IIII1020.50 Squidget3533.50 Game7432.50 StickyPickle1592.00 InspectorSeb115.00 ///M TOWN20312.00 Tag18377.50 uk0168573.50 M Division1199.00 Chicanery80.00 gcmak135.50 apez656.00 frostyrwd61.50 RichyN25.50 Sculpin279.50 Baller151.50 ourlee920.00 LCDRJohn607.50 MovingChicane109.50 M2Aioli43.50 Digitalprty127.50 itf joegun169.00 Resoelg258.00 |
05-12-2023, 10:13 PM | #3 |
Enthusiast
80
Rep 281
That’s amazing ! That was a lot of work to put this together. Thank you ! Is there a reason for the difference in front and rear spacer recommendation ? Is the front stock setup more inset than the rear stock setup ?
Anyway you can do the same with lowering springs ? What is the recommended drop ? Would the front be dropped more than the front to achieve symmetry ? It looks like the front wheel gap is more than the rear. The wheel gap is pretty atrocious right now, especially the front !
2023 G87 M2, Brooklyn grey, HEA spec, 6 spd manual
2014 911 Carrera S, Agate grey, black int, 7spd manual 2019 M2C, HKS, 6 spd Manual. (Sold) |
08-03-2023, 02:57 PM | #5 |
Rep 88
I decided on 12mm front and rear. I consider this flush, the rim to fender in front and rear are now nearly identical.
One thing I discovered though, and I have the PZeros - and I know you only tested the PS4S - with the 12mm spacer up front, backing up onto my driveway (which is slightly off camber)...if i have the wheel turned 50%+, the tires will catch those vents on the fender liner. It's actually cracked one of the vent louvers on my driver side. I haven't done a side-by-side but I believe the PZeros might just be a hair wider in the tread width than the PS4S option. Hope this helps someone else. |
08-03-2023, 03:21 PM | #6 | |
Rep 1,547
08-03-2023, 03:26 PM | #7 |
Rep 88
I'm not paying for those aftermarket liners just yet! Will see how this bothers me down the road. I will be adding camber plates which again might change the situation...hopefully for the better...but I alway say stock #1 if you don't want headaches!
Squidget3533.50 |
08-08-2023, 09:18 AM | #9 |
Rep 866
Have we determined the sweet spot for not rubbing in front when wheel is cranked? Seems like stock height 15 or 12 front have potential to rub. But once lowered there is a bit more room. For example maybe M Perf HAS port installed at their 10mm drop allows for 15 f without the rub?
KevM2724.50 |
08-08-2023, 09:21 AM | #10 | |
Rep 803
08-08-2023, 11:04 AM | #11 | |
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
08-08-2023, 02:47 PM | #12 | |
Rep 803
I just ordered wheels that will be the equivalent of having 15F and 18R spacers. Once lowered it should be perfectly flush. |
08-08-2023, 03:05 PM | #13 | |
Rep 929
08-08-2023, 03:20 PM | #14 | |
Rep 803
What a lot of people seem to be doing with G87 spacers right now is lining up their tire to be flush with the fender, but what you want (especially when lowered) is the lip of the wheel to be flush and the tire very slightly in. If you look at IND's pics above, 18mm rear with 1-2 more degrees of camber would be perfect. 18 in the front might be ideal as well but I'm going for 15 fitment on my wheels to be safe (19x9.5 +5) Example on my F87 - |
08-08-2023, 03:35 PM | #15 | |
Rep 1,510
Drives: G87, G26, E46, Mk6 5K
08-08-2023, 07:59 PM | #18 | |
Rep 866
Looking forward to seeing your 18r, 15f equivalent fitment. Please post pics and observations re fitment, rubbing on liner etc once you get them on. Thanks! |
rcouchh2376.50 |
08-08-2023, 08:04 PM | #19 |
Rep 803
For sure, will be posting lots of content on here and IG. Unfortunately the wheels are about 9 weeks out
08-15-2023, 10:37 AM | #20 |
7433
Rep 10,239
Yep my car just got lowered and can definitely do 18mm all around. The 15mm up front is fine..but could use a little bit more. Currently running 15f/12r but that'll change.
08-17-2023, 12:18 AM | #21 |
Rep 866
08-17-2023, 11:58 AM | #22 |
7433
Rep 10,239
Lowering it got rid of the rubbing. So glad I didn’t do any cutting.
Up front I lowered it about 28mm. |
