05-24-2023, 07:40 PM | #1 |
Not great. Not terrible
7448
Rep 2,700
Carbotech 1521 pads installed!
Received and installed my Carbotech 1521 pads today! Install was easy peasy, maybe 30 minutes per wheel at most. Rear was also super easy after putting car in service mode using bimmerlink.
Carbotech says no bed in needed for 1521 just drive "normally" for 3-400 miles. Well "normal" for me is hard, so let her rip I guess! Anyway, I did go for a quick 20 minute run and I cannot tell any difference in bite and stopping power between these and the OEM, so that's good! They may even be better, but I have no scientific way to state that definitively. I can say that I didn't detect a DECREASE in performance so that's good. How bad they dust will take some miles to tell. I'll try to avoid washing my new wheels for a few hundred miles to post an after pic, but I did take a pic after my 20 mile run. Very little dust and it's more brown than black. So far so good! The only "issue" is on the front pad, the cut out for the wear sensor didn't quite fit snugly enough so I just tied off the sensor. I'm never going to use it to decide on pad replacement anyway. Here's the wheel after nearly 1200 miles and before washing. OEM vs Carbotech fronts. OEM vs Carbotech rears. I like the blue vs red. Also while I had the wheel off, I put in the yellow DRL modules. I snapped a pic of the brake cooling duct for curiosity. Two swipes of a finger to get dust of the new pads. I'll post back after a few hundred miles on how they're doing and how the dust is!
Current: 2024 BMW X3 M40i.
10
Hypori142.00 StickyPickle1592.00 M2-Bob245.00 Sherlock997220.00 Chet for short203.50 79 911SC85.00 cmgbk752634.50 johnnie311197.50 M Division1199.00 ourlee920.00 |
05-24-2023, 08:02 PM | #2 |
Rep 778
Subscribed, definitely interested to see how much these reduce the dust. I was trying to cheap out and avoid getting these, EBC Redstuff or iSweep 1500 but looks like I’ll have to bite the bullet if I want to get a quality pad that is decent at reducing brake dust. Plus there’s not many other good options out there in this class that offer front pads.
I don’t think the EBCs do as good as good of a job compared to the Carbotech and iSweep and plus you can’t find any of the fronts in stock so I’m down to those 2. |
JustinHEMI7448.00 |
05-24-2023, 08:05 PM | #3 | |
7448
Rep 2,700
StickyPickle1592.00 ronin130131000.50 |
05-25-2023, 01:13 AM | #4 |
Rep 63
A timer app could have given you your 60-0 times and distance before and after.
Sure you need to give time for your new pads to settle and try the test at the same time of day and same weather/temperature but this kind of data is invaluable I find despite the hassle. |
05-25-2023, 05:35 AM | #6 | |
Rep 3,026
Drives: A Family Sedan
What we’re looking for is fade resistance. But that’s hard to measure. And if OP is never tracking the car he may not need to ascertain that anyway. I’d be interested to see if it fades more quickly than stock, but I’m not sure a scientific controlled method is possible or easy to do at home. How much did they run you OP? |
05-25-2023, 07:47 AM | #8 | |
Rep 158
05-25-2023, 07:56 AM | #9 |
Rep 3,026
The inability to continue to help the car decelerate at maximum efficiency after repeated attempts, where heat has built up.
As brakes heat up they lose efficiency and the friction coefficient is reduced. If heat is extreme, brakes can totally fail. This normally only happens if driving down a mountain pass riding the brakes (reason why we need to reduce gears to help the engine brake hold the car) or driving on the track. Bigger brakes have more area to absorb the heat exchange and thus have less tendency to overheat (reason why faster/heavier vehicles have larger brakes). Pads come in different materials that help with brake fade (some materials work better in higher temperatures). Some materials, like “ceramic” pads are great for brake dust as they don’t generate as much, but do not resist to heat as well as metallic materials. They “melt” under extreme use. It’s always a compromise. They’ll all stop the same way, but some will continue to help the car stop for longer periods of braking. |
05-25-2023, 12:26 PM | #10 | |
Rep 1,547
Brake fade can be most dangerous when you boil your brake fluid. Boiled fluid becomes compressible, and that means no hydraulic pressure. This happens super quickly, so your brakes can be fine one moment and totally gone the next. That's why semis crash so often coming down mountains; by the time the driver notices it's too late. |
05-25-2023, 12:43 PM | #11 | |
Rep 3,026
Air is always pushing the pads out of the rotors, and when you push the pedal that pressure is alleviated to have the pads put pressure on the rotors. So when their brake assistance fails, the brakes lock up. That’s why sometimes you see skid marks on highways. Sometimes it was a near (or full on) accident, but sometimes it was a brake failure (so they locked up). Anyway, a bit of digression sorry! |
05-25-2023, 03:35 PM | #12 |
your average JAMF
3167
Rep 4,106
Drives: '21 M2 Comp, '19 Golf R
I’ve got about 8k miles on mine. MUCH happier than with the stock pads. More linear feel, and in my usage which is 99% daily driver stuff, virtually no dust.
05-26-2023, 04:50 PM | #13 |
7448
Rep 2,700
About 150 miles with hard braking. Also, they do squeak at low speed, like creeping up at a stop light or pulling into the garage. That said, squeaking was never a problem for me.
05-26-2023, 06:49 PM | #14 |
Rep 778
05-26-2023, 08:09 PM | #15 |
7448
Rep 2,700
05-28-2023, 09:41 AM | #17 |
7448
Rep 2,700
I read this from Carbotech on another forum,
"Squealing and dust will reduce over ~1k miles or a few months as the stock pad material is removed from your rotors." So I'll continue to update. About 450 miles now. I should note that what squeaking I do hear from time to time is nothing compared to OEM.
StickyPickle1592.00 |
05-28-2023, 10:32 AM | #18 | |
Rep 778
05-28-2023, 10:36 AM | #19 | |
7448
Rep 2,700
Yeah I agree and when I saw this, it made sense. My rotors were well and bedded with OEM pad material and if I'm not going to knock it off another way, then these pads need to work it off over time. I think this dust is easier to clean but I'll know for sure in a bit. When Headed out to give her a bath. I was going to avoid washing the wheels for a while but I had them rebalanced yesterday and now they have hand prints all over them, so starting fresh. Plus I need to get some more photos for Richland Forged. When I finger swipe the dust, it doesn't seem as thick and sicky as OEM.
05-29-2023, 06:26 PM | #20 |
7448
Rep 2,700
200 miles or so since yesterday's wash. Not a lot of dust.
06-04-2023, 05:31 PM | #22 |
7448
Rep 2,700
Probably my last update on these unless something goes wrong because overall, I'm happy with them. They do dust less, it's a different kind of dust that is easier to clean and doesn't turn brown, the braking seems at least as good as OEM. They do squeak a little from time to time but it's barely noticeable as compared to OEM. They aren't dust free if that's what you're after.
All in all I think they're a decent option. This is after a few hundred more miles. I could "live" with that dust on there a while, whereas the OEM dust would have been browning and such. I do need to give her a bath as she'll be on video next weekend. Lastly, cosmetically, I like the little touch of red back there with the blue calipers. It all kinda goes with the 50th anniversary emblem on the wheel caps.
