06-01-2023, 04:10 AM | #1 |
Rep 4
Are Bootmod3 Exhaust Settings Adjustable While Running Stock Map?
I'm trying to do cold-start delete to not get noise complaint (and I have a catless downpipe too so no need to warm cat). But I do not want to run stage 0+, stage 1 or stage 2 yet.
Does Bootmod3 allow me to customize my stock ecu tune to disable cold start? |
06-01-2023, 04:23 AM | #2 |
Rep 4
Is Bootmod3 compatible with a car that had Bimmer Remote Coding done?
I had Bimmer Remote Coding do GTS package on my N55 M2 6MT which claimed to have change Steering, Differential, MDM and EDC to match GTS/CS. Would this affect how Bootmod3 unlock my DME? I have not flashed it yet and don't want to brick it. If I were to flash, it would be my first time. I am not running any other tune. It is simply BMW OEM map used in the GTS/CS models according to Bimmer Remote Coding.
06-01-2023, 04:00 PM | #3 |
Rep 226
You can turn off catalytic heating in the map config for stock tune.
06-01-2023, 04:12 PM | #4 |
Rep 19,116
Yes, this is possible. Depending on the production date of your MY18, the DME may require bench unlock - we can do this for you.
06-02-2023, 01:28 AM | #5 |
Rep 473
While BM3 will get the job done, I'd be curious if they're was any other way that didn't involve spending so much to only use 1 small function.
