06-01-2023, 11:34 AM | #2 |
Rep 116
There are lots of variables, but in general the 21" setup will be heavier. Someone measured the Audi OEM 20" and 21" wheels + tires and the total weight difference is ~13kg (21" being heavier).
In terms of how this additional rotational weight impacts acceleration and handling, I found this controlled experiment quite useful as a frame of reference: https://www.caranddriver.com/feature...-wheels-tires/ - As wheel size increases, acceleration and fuel economy get worse, while braking distance improves - Cornering (skidpad g-force) improves as wheel size increases, but peaks at 18" and tapers off at 19" in this particular setup |
phillipp17.50 |
06-01-2023, 03:11 PM | #3 | |
Rep 1,230
I assume that same sweet spot would typically be 18"-19" on a D-segment mid-size sedan (e.g. 3 Series) and 19"-20" on an E-segment executive sedan (e.g. 5 Series), which are designed for bigger overall tire sizes; and that going for the bigger rim option within that 1" range will have smaller potential negatives than on a Golf, since the bigger the tire is to begin with, the more incremental each extra inch of rim will feel within that given diameter. So if for example 20" happens to be the optimal size on the 5er but one really likes the style of those 21" that are being showcased, perhaps the negatives of the 21" will be minimal, especially coupled with the more high-end adaptive chassis you can get on a 5er compared to lower segments. The biggest considered option needs to be tested in real life, I guess. Last edited by advantage20; 06-01-2023 at 03:19 PM.. |
phillipp17.50 |
06-07-2023, 10:42 AM | #4 |
Rep 21
Okay. The more I learn the more I'm confused. BMW says best range is with the 19" wheel and range gets worse with larger wheels. Well, if tire diameter stays same regardless wheel size, then how is range affected?
If you have a 19" wheel the tire has more sidewall. If you have a 21" wheel the tire has less sidewall. But tire diameter is same irrespective of wheel diameter. What am I missing? |
06-07-2023, 11:29 AM | #5 | |
Rep 1,230
Then again, the step from 20" to 21" on a 5er is likely more incremental than, say, the step from 18" to 19" on a Golf. Unless 21" really happens to fall way beyond the sweet spot, which you should check the given numbers for again and test drive in any case. To be fair though the bi-color M Sport 20" already look fine and just big enough, don't they? Last edited by advantage20; 06-07-2023 at 01:39 PM.. |
06-08-2023, 12:11 AM | #6 | |
Rep 21
06-29-2023, 11:42 PM | #7 |
Rep 21
New question - what are "mixed" wheels and tires? When configuring the new i5 there are options for A/S (all season of course) and mixed on what appear to be the same wheel design.
06-30-2023, 12:41 AM | #8 |
Rep 150
06-30-2023, 03:50 AM | #9 | |
///M driver
16417
Rep 500
Drives: 2022 M3 6-speed
I see an error in the G60 i5 pricing guide, they call the 19" non-staggered setup mixed; it is not.
'22 G80 M3 6-sp Portimao Blue/Tartufo
06-30-2023, 06:21 AM | #10 |
Rep 1,185
Drives: 2023 M550i CBM/Ivory
in general, bmws have offered mixed (staggered) all seasons as well.
07-31-2023, 10:24 AM | #11 |
Rep 769
When I ordered my G30 540i with A/S tires I didn’t realize it forced me to a lower speed limiter, 130 mph I believe. Disappointed, I searched for ways to get this increased to 155, just to have it, but it is hard coded to the car from the factory and can’t be changed. Reality is I’ve probably never been over 100 in the car and so this hasn’t been an issue. If you really want the 155 limiter order the mixed performance tires.
Bluegrass Bimmers
Current: 2019 G30 540i M Sport | 2022 & 2018 G01 X3 xDrive30i Past: 2017 F30 340i M Sport/6MT | 2013 E70 X5 3.5 | 2011 E90 ///M3 6MT | 2005 E46 330i ZHP 6MT | 2001 E53 X5 3.0 | 2000 E39 528i Sport/5MT | 1998 E39 528iA | 1997 E38 740i | 1993 E36 318is |
08-04-2023, 08:47 AM | #12 |
Rep 769
Any idea what the wheel offsets are for the 20” wheels? Usually can find them on RealOEM but haven’t found them yet…too early. I like some of the 8 series wheels better and might swap for them if they fit.
Bluegrass Bimmers
