06-03-2023, 11:41 AM | #1 |
Rep 15
Front Plate Bracket - Tow Hook
For those looking for tow hook license plate mounts, I've aggregated some reviews and pictures with the 3 mounts known to work here; Ebay, EOS, RHO. Note that each of those has a link to the products themselves. You can follow links in the reviews to the original forum posts froom users with pics.
Ebay:$30 Review from bislag: Worked perfectly. Only note is that the plate rotates a little easier than I’d like fully tightened. That said, its not loose and hasn’t budged in the slightest in the weeks/miles since I’ve put it on. Its very adjustable and with how I positioned the plate on the bottom right mounting location, no interference with sensors. I have not experimented with other positions. Original review with pictures at following link: https://g87.bimmerpost.com/forums/sh...1&postcount=13 Eos plate holder:$80 or https://eosplates.com/collections/bm...40152000987285 Review from Squidget : Works fine on the G87. It comes with (2) 7mm spacers, I used one. It seems reasonably secure, except I worry it's going to rotate. There's no keying in the assembly to prevent the plate from rotating over time, and I'm going to keep an eye on it. It's reasonably adjustable on the yaw axis. The plate holder itself has plenty of mount points so you can position it. Because I'm worried about rotation, I mounted the plate dead center over the tow hook spot. I think it looks fine there, but you could push it leftward if you wanted. I wouldn't put it in a car wash. It's not a quick-release system, so if you go to car washes, this is probably not the product for you. Original review with pictures at following link: https://g87.bimmerpost.com/forums/sh...8&postcount=24 RHO: $109 Review from Trogster: I've used many tow-hook style brackets over the years and I can honestly confirm this is by-far, the best design I've ever used. Original review with pictures at following link: https://g87.bimmerpost.com/forums/sh...6&postcount=49 -----Original post from before mounts were found below------ Does anybody know of tow hook plate bracket that is confirmed to fit the G87 M2 (and not interfere with the sensors)? Any of our vendors here know of one in the works? My plates finally came in the mail and my temp tag doesn't have much life left. Apologies if I missed it, but I haven't seen any on any websites or forums advertising one. I believe I've seen them for the prior gen M2 and current 2 series, but not the G87. And just to cover the usual responses I always see to this;
Last edited by bislag; 07-08-2023 at 07:16 AM.. Reason: Update for product links/reviews |
06-03-2023, 12:09 PM | #2 | |
Rep 1,510
Drives: G87, G26, E46, Mk6 5K
bislag33.00 Chet for short203.50 |
06-03-2023, 12:13 PM | #3 | |
Rep 778
bislag33.00 |
06-03-2023, 10:03 PM | #5 |
Rep 183
They do make nice billet universal mounts for tow hooks.
Not sure how well it would work. I bought one for my Mclaren and used it until they made a custom piece that screwed under the splitter. That thing was awesome. It has a quick release and you could remove the plate in 5 sec. For the M2, I am going to ask my friend to make me a 3-d printed one that I can put in the radiator gap. Not great if U want to track the car tho. I don't know how much it would effect cooling. For the street, no worries tho. Last edited by LCDRJohn; 06-03-2023 at 10:17 PM.. |
bislag33.00 johnnie311197.50 |
06-04-2023, 07:28 AM | #6 |
Rep 15
Thanks. I didn't mention it in my post, but I did try one of the generic ones from ebay that said they fit the G87 M2. Not sure if that's what you're referring to though. Unfortunately the tow hook piece that screws in needs to be 1-2" longer. I didn't measure, just an extraordarily rough guesstimate to what would be needed to get it out from inside the bumper and provide enough clearance for the plate bracket.
I did provide feedback to the seller, so maybe they'll refine it, but I always only considered it a placeholder solution. Its very adjustable, but it's not something that seems like it'll hold up as a consequence. |
LCDRJohn607.50 |
06-04-2023, 10:54 PM | #7 |
Rep 1,547
I have a kit I'm going to try when I get my car at the end of this month, I'll report back then. Sorry, until then, I've got nothing to add.
Edit: It's an EOS. |
06-05-2023, 12:14 PM | #8 |
Rep 3,026
Drives: A Family Sedan
After moving from a province that doesn’t require a front plate, I installed a hidden mount under the bumper. I don’t use it much because cops around me don’t usually ticket for front plates, so I just don’t run any, and I have it in the trunk so I can throw it on the dash if needed…
Hope I helped. |
06-06-2023, 08:15 AM | #9 | |
Rep 15
For reference the tow hook post on the ebay bracket I mentioned is 4.75" if you don't count the threads. That's still not enough to get it even flush with the bumper, probably a 1/2 an inch short from being flush (eyeballed). Then there's the bumper features that the bracket still needs to clear. The seller of the ebay mount is sending me a longer post right now. I'm not particularly optimistic the bracket will work out since they only said "longer." But we'll see. I'll take more measurements once I get the replacement regardless. Also, great job covering all the bases M2siast lol |
M2siast5949.00 |
06-06-2023, 09:14 AM | #10 |
Rep 1,547
It's for a G80, IIRC and yeah, I have no idea if it will work, I'm just trying things to see if they work. I'll measure the shank tonight.
06-06-2023, 10:09 AM | #11 |
Rep 1,547
When I first saw a G87, my CA and I looked at the bumper and brainstormed the problem. We came up with three options.
Tow hook is preferred and we think it can clear all the sensors. After that we'll try zipties to the lower grill. I'm getting a manual so there's no adaptive cruise control sensor to worry about. Last resort is double sided tape. Obviously this has issues and totally rules out car washes. I'm probably unwilling to do this unless we can get a really good seal. I'm not the kind of asshole who would have a loose piece of metal that can fly off on the highway and cause an accident. If it comes to this, I'll probably suck it up and drill the bumper. Running without plates is not an option where I live, cops WILL ticket you. |
06-06-2023, 10:23 AM | #12 |
Rep 1,547
Just measured. The clearance is about 6 1/8" from threads to back of plate. Plus there are two optional spaces, 7mm each, that can be added.
So call it 6 5/8" clearance. FYI: I think it was this kit: https://www.amazon.com/gp/product/B094638633 |
06-07-2023, 07:53 PM | #13 |
Rep 15
Success! I might move to a different mount once available (or maybe the one Squidget posted), but the ebay mount now works. The EOS mount squidget posted in this thread should also work with the spacers based on the measurement provided.
The ebay seller sent a longer post, 6.5” without counting threads vs the original 4.75” they had sent. It worked. Only complaint is that the plate rotates a little easier than I’d like fully tightened. That said, its not loose. On a short drive hitting speeds of 70mph it did not move. Its very adjustable and with how I positioned the plate on the bottom right mounting location, no interference with sensors. I did not experiment with other positions. Link to item. https://www.ebay.com/itm/364202158561 Theyll ask model of car. I’ll be sending my feedback to them shortly so they know what to send future buyers. All in all I consider it worth the $30 spent and recommend it. I will update the review here if I have any issues or change my opinion. Pics below. Apologies for rotated images. Not bothering to fight the erroneous rotation issue on upload while on mobile. |
06-07-2023, 10:44 PM | #15 | |
Rep 3,026
06-22-2023, 05:46 AM | #16 |
Rep 32
06-23-2023, 04:31 PM | #19 |
Rep 15
Definitely eager to see how that one works out. Been toying with the idea of editing the first post to throw links up to products that are known to be good once more folks confirm fitment.
06-26-2023, 02:33 PM | #20 | |
Rep 1,547
In the meantime, the RHO plate seems to be a good option? https://g87.bimmerpost.com/forums/sh...6&postcount=49 |
06-27-2023, 12:18 PM | #21 |
Rep 1,510
I ordered the RHO tow hook mount.
Did Expedited shipping for $14.95. Unfortunately it’s coming from Cali and has an estimated ETA of 3-6 Business days. I’ll keep the car off the Ticket magnet City streets until then. |
Squidget3533.50 |
