BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Removing adhesive from spoiler on matte paint
      06-04-2023, 12:01 AM   #1
fpgg80
Drives: 2023 M3 Competition
Anyone know if wd40 or 3m general adhesive auto remover is better for getting the adhesive off from the oem spoiler? Or any other suggestions welcomed
      06-04-2023, 12:29 AM   #2
jayg80
jayg80's Avatar
Drives: M3
I have had success with 3M adhesive remover, wouldn’t use anything else. Can’t speak to wd40.
      06-04-2023, 12:32 AM   #3
iviegatron
iviegatron's Avatar
Drives: G80 M3
You can use the 3M general adhesive remover but you still need to use an eraser wheel (link below) to make life easier. It attaches to any drill. Otherwise you'll be scraping the adhesive for a long time and it won't be too effective.
Wonder Wheel 4" Decal Remover Eraser Wheel Toolkit, Remove Car Decals, Vinyl & Stickers in Minutes, Adhesive Remover Rubber Wheel, Emblem Removal Tool, Adhesive Eraser, Drill Adapter Supplied https://a.co/d/cSkozOU
      06-04-2023, 12:29 PM   #4
Pentland
Drives: BMW M240i (G42)
AutoGlym tar remover removes most sticky stuff.
      06-04-2023, 12:40 PM   #5
LuxoM3
(formerly exe36M3)
54
Drives: 2015 BMW 435i
1. Rub what you can off with your fingers.
2. Follow-up with WD-40 and a paper towel. Make sure the towel is fairly "wet" with WD-40.
The towel is "aggressive" enough to pick-up the adhesive, the WD-40 breaks down the adhesive and keeps it from resticking.
3. Use a degreaser like Simple Green or quick detailer with a microfiber to get the WD-40 off the body.
4. Give the area a small patch of wax to protect the paint.
WD-40 is amazing for getting decal residue off paint.
BMW CCA Member | 2015 BMW 435i RWD, Stage 1 Bootmod3
      06-04-2023, 12:44 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Same here.
Don't need chemical solvents, just use and eraser wheel.
goto 6:30 for eraser wheel.
'21 M2C Hockenheim Silver
      06-04-2023, 02:23 PM   #7
skyline408
skyline408's Avatar
1626
Drives: 2023 G80 M3 2022 F95 X5M
Wax, eraser wheel, buffing?
I'm guessing many here are not familiar with frozen/matte paint as you CANNOT rub the paint!
I don't know what kind of adhesive is left, but if you can just slowly pick at it without rubbing the paint, that's your best bet. Other than that, maybe take it to a shop that has experience with frozen paint and see what chemicals they recommend.
      06-04-2023, 02:32 PM   #8
Anderson11
Anderson11's Avatar
464
Drives: 2023 BMW M4 Comp
The all natural solution. Works great....https://googone.com/goo-adhesive-remover-spray-gel
2023 M4 Comp
Dravit Grey Metallic
