BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Modded 335i compared to an SLK55 AMG
      01-20-2009, 06:19 PM   #1
Cyrax91
YNWA
Cyrax91's Avatar
Drives: Imola Red F80 M3
Hi guys,
I just randomly went by the Mercedes dealership here to maybe see the new C63 they had an 06 SLK55 AMG and I took it for a drive. The V8 sounds awesome, but I felt like even with 380 whatever ft/lbs of torque there was no way it pulled as hard as my Vishnu 335i. It just seems with that little car and all its horsepower and noise it should fly. Has anyone experienced driving say an SLK55 or maybe something even bigger like the CLS55 that can give me an idea of what any differences are from a modded 335i?
Thanks,
Dimitri
Imola Red ZCP F80 M3
      01-20-2009, 06:21 PM   #2
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
Drives: circles around you
what is up with these vs. threads lately?
      01-20-2009, 06:23 PM   #3
Cyrax91
YNWA
Cyrax91's Avatar
I think ive just been really curious recently as to what other cars drive like. And I want to know if anyone else has felt the same and could give me some info on other autos.
      01-20-2009, 06:24 PM   #4
Boost Gomez
Boost Gomez's Avatar
Drives: C63 AMG
2007 BMW 335i  [0.00]
+1
      01-20-2009, 06:55 PM   #5
ejazbmw
blahhh
ejazbmw's Avatar
320
Drives: 2014 M235I
+2
fanboys
      01-20-2009, 08:28 PM   #6
darkphantom
Drives: E93 335i
wow, what a heavy little pig! 4079lbs! heavier than my cabrio!
      01-20-2009, 10:14 PM   #7
bluescoupe
motorhead
bluescoupe's Avatar
60
Drives: 2017 M2
the 335i is certainly the fastest car alive; if you are not sure of this fact, race it (stock, of course) against any and all competitors (or imagined competitors)...
      01-20-2009, 10:31 PM   #8
TheAcAvenger
TheAcAvenger's Avatar
Drives: 2018 R35 GTR / 2007 E92 335i
It's not faster. I had a rendezvous with an 05 C55 AMG that has the same engine in it and pulled.
A CLS55 on the other hand... hahaahaha. That has the big boy engine in it. Back in the old days of E90post, there was a guy named Walked U that had some run-ins with M5s and CLS55s and he would tie them at best. I still don't think there are any cars up here as modded as his was except for the tuners and the and a couple others that put down 400whp+. The 55s that were put into the higher end models were much higher in output than the engines MB put into the SLK and the C.
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
      01-21-2009, 02:53 PM   #9
1BMW4fun
Drives: 12 X3 2.8, 11 550
Those little suckers are pretty quick, I lost to one pretty bad in my old E90 330. They have a curb weight of 3472lbs and seems they have a faster "Ring" time than a stock 335i.
      01-21-2009, 02:58 PM   #10
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
A tuned 335i should win. Here are brand new test results of an '09 facelifted SLK55: http://blogs.edmunds.com/straightlin...hotopanel..2.*
Originally Posted by Insideline
The 2009 Mercedes-Benz SLK55 is the one of only two AMG models left that doesn't use the latest 6.3-liter V8. Instead, it gets by with an older 5.4-liter V8 that produces 355-horsepower. Sounds meager next to the 500+ horses belted out by the bigger 6.3, but remember this is a 3,500 pound roadster.
Compared to the standard SLK350, the AMG model also gets a fully upgraded suspension, larger wheels and tires, and upgraded brakes. For the record, there's an even more aggressive AMG Performance Package available for an extra $7,000 that adds an even stiffer suspension, new wheels and revised brakes.
Vehicle: 2009 Mercedes-Benz SLK55 AMG
Odometer: 6529
Date: 01/06/09
Driver: Chris Walton
Specifications:
Drive Type: rear wheel drive
Transmission Type: 7-speed Automatic
Engine Type: V8
Displacement (cc / cu-in): 5439cc (332cu-in)
Redline (rpm): 6,600
Horsepower (hp @ rpm): 355 @ 5.750
Torque (lb-ft @ rpm): 376 @ 4000
Brake Type (front): ventilated disc
Brake Type (rear): ventilated disc
Steering System: speed-proportional power steering
Suspension Type (front): MacPherson strut
Suspension Type (rear): multi-link
Tire Size (front): 225/40ZR18
Tire Size (rear): 245/35ZR18
Tire Brand: Pirelli
Tire Model: PZero Rosso MO
Tire Type: performance
Wheel Size: 18 X 7.5 front - 18 X 8.5 rear
Wheel Material (front/rear): alloy
As tested Curb Weight (lb): 3,474
Test Results:
0 - 30 (sec): 2.1
0 - 45 (sec): 3.3
0 - 60 (sec): 4.9
0 - 75 (sec): 6.8
1/4 Mile (sec @ mph): 13.0 @ 108.8
0-60 with 1-ft Rollout (sec): 4.6
30 - 0 (ft): 29
60 - 0 (ft): 115
Braking Rating: Excellent
Slalom (mph): 66.2
Skid Pad Lateral acceleration (g): .87
Handling Rating: Very Good
Db @ Idle: 48.4
Db @ Full Throttle: 80.3
Db @ 70 mph Cruise: 69.1
Acceleration Comments: With ESP on, the traction control system does an admirable job of containing the power. Shutting it off in "Drive Sport" ushered in a 1-2 short shift as the first hint of wheelspin. Had to resort to manual mode to achieve a decent launch, but then the slow tach had it hitting the rev limiter. Difficult, though not impossible, to get under 5.0 to 60mph and in the 12s for the quarter mile. Upshifts are sometimes slow/fast or smooth/harsh and I cannot determine why.
Braking Comments: Excellent brake power and fade resistance. New zero nose dive and pedal always felt trustworthy. Autobahn brakes.
Handling Comments: The very definition of "pushy-loose" where it understeers on throttle and snaps into oversteer when you jump out. Tenuous at best and dangerous at worst with ESP off in manual mode.
Like the skidpad, the SLK55 can be a handful in the slalom with ESP off in manual mode. That said, turn-in is crisp up to 9/10ths then starts to understeer. Throttle response is terrific, so a slide at the end is easily requested, but the short wheelbase makes it tricky to control. The PZeros step off pretty abruptly then slide predictably. This is how I imagine a V8 Monster Miata would feel.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
      01-21-2009, 05:22 PM   #11
marty_mcfly
Drives: ???
modded 335i > stock slk55
stock 335i < stock slk55
its as easy and simple as that.
      01-21-2009, 05:49 PM   #12
hl0m4n
hl0m4n's Avatar
the slk55 is a beast, i was about to get one when deciding 335i vs. slk although i also had the m roadster in mind with an e46 m3, c55, and clk55 at the time.
i got the 335i as to slk55 cause i needed the trunk and rear back seats. to me it was more practical of a car. now if i did get the car it would have ecu, intake, headers,and exhaust and that will give any tuned 335i a run for their money .
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
