06-07-2023, 10:36 PM | #1 |
Rep 130
Clunking noise/jolt under hard acceleration through low gears 1-3. No noise/jolt while driving regularly. Feels like it’s coming from the front end and middle under body of vehicle. Could it be my engine mounts? Car is perfectly smooth on shifts driving moderately, only say for instance when I cruise at 25mph 3rd gear, then slam the gas after automatic gearbox drops to 2nd to build that torque, the car car will clunk. Vehicle is going to my indie shop on Monday for diagnosis.
06-08-2023, 07:21 AM | #2 |
Rep 6,862
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Sounds like engine or transmission mounts to me. How many miles on the car? They don't usually need replacement until 100k miles, but if you or the prior owner has been hammering it consistently, they could be shot.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
06-08-2023, 01:28 PM | #3 |
Rep 1,653
Could be the thrust arms/lower control arms.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
Scott in Houston77.50 |
06-08-2023, 04:44 PM | #4 |
Rep 130
I’ve got 52k… other than the mounts and or guibo, I’ve done research and have also came across the possibility of a bad VANOS actuator.. I started to develop this odd “pigeon cooing” sound in my engine bay on cold start, it’s a throbbing rhythm that goes away once the engine is up to temp, Only will do it on idle and not while driving. I posted my symptoms on Reddit and this man posted that he was having the same symptoms and found the video online where a failing VANOS actuator was the culprit for this weird thumping when slamming on the pedal. It’s not outputting the right timing or something causing these symptoms… will be ordering one and replacing my exhaust side, thinking about doing the intake side as well. What do you all think ?
06-12-2023, 05:45 AM | #6 |
Rep 6,862
That's good you got to the bottom of it and it's an easy fix.
06-12-2023, 09:00 AM | #7 |
Rep 647
Great that you got the "clunk" figured out.For a while I was thinking it might be something more serious, as depicted below. I know, I have posted this before, but sometimes I can't resist posting it on a "clunk" or "ticking sound" thread. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
HerkHealer1751.50 G30 B581556.50 |
06-12-2023, 05:48 PM | #9 | |
Rep 1,671
This makes me think back to my C-130 Crew Chief days in the USAF. Every single toolbox handed out was inventoried at the beginning and end of every shift. It was a pain in the ass. But every now and then, something would come up missing. It usually involved every single person scouring every inch of where that person had worked on that shift. Often including "grounding" the Acft from flying. There were several times that we never found the missing item and the Squadron Commander had to sign an "exceptional release" to let the plane fly again. 100% this still happens today. Especially in the commercial airline world.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
NGT25766.00 |
06-12-2023, 06:45 PM | #10 | |
Rep 5,409
06-13-2023, 05:41 AM | #11 | |
Rep 15,858
Car had been serviced, there's a rattle in the engine bay. I find an oily pair of grips, between the fire wall and bulkhead. Take them back to the garage... Was told "we don't use them for servicing", therefore "don't belong to the garage". Would of been even better, if they were a top quality pair of grips. |
06-13-2023, 10:31 AM | #12 | |
Rep 647
HighlandPete6663.00 |
