06-18-2023, 11:37 PM | #1 |
Rep 42
Rear Passenger vibration after 75mph
Hey guys I’ve been trying to pinpoint this weird vibration I’ve been having in the rear passenger side. So I don’t feel it much or at all under 60 mph but after I pass 75-80 mph on highway I feel it after I let off the gas, I don’t not feel it while accelerating however. I thought it was an off balanced tire and alignment and got new tires since it was time anyways all around and alignment. After that it did lessen it way more but I can still feel it, passengers can not but I def can feel it. Any ideas or what I should look at would be appreciated thanks
2014 335i M Sport 6MT
06-19-2023, 10:02 AM | #2 |
Rep 10,319
How many miles does the car have? Were the tires RoadForce balanced? Were the rear wheel bearings inspected?
With the caveat that the remote diagnostics are what they are: it's unusual for the passengers not to experience vibrations as they are much closer to the source. |
murd0x7.50 |
06-19-2023, 11:11 AM | #3 | |
Rep 42
But ya I ask my friends if they feel that slight vibration coming from the rear and they def don’t notice it especially when I did a 3 hour road trip with them in the car last weekend.
06-19-2023, 11:30 AM | #4 |
Rep 487
Check the tire balance first. The next to check is the control arms and the condition of all the bushings. Also check the strut/dampener - the bushing at the bottom and the top mount just in case. In order for such vibration to be caused by the bearing, the bearing has to be really bad and the noise coming from it would be extremely noticeable. My bet is on the tire/wheel and the bushings as next choice. Have had the same issue in the past - the 2 piece Cromodora rim at the rear was unbalanced (example).
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
murd0x7.50 |
06-19-2023, 11:47 AM | #5 | |
Rep 42
cfm56d7b5948.50 |
06-19-2023, 11:50 AM | #6 | |
Rep 10,319
Bent rim would be easily detected by the tire balancing process. Please keep us updated! Last edited by cfm56d7b; 06-19-2023 at 11:56 AM.. |
