06-19-2023, 01:35 PM | #1 |
Rep 80
Drives: 2020 bmw m550ix
replace engine air filter g30 m550ix
Howdy all. Ordered new engine air filters and when I got started to try and remove the current, I couldn't get the air box off. Looks like a brace is right at the attachment for the air box and hose assembly. Do I need to remove the brace to get the filter out? Thanks in advance
06-19-2023, 03:48 PM | #2 | |
Rep 886
06-19-2023, 10:15 PM | #3 |
Rep 495
Assuming here we're talking about a 2020+ engine. You can change the filter without removing the air box, but if you don't remove it you won't be able to vacuum out any debris trapped in the box.
10-12-2023, 10:37 AM | #4 |
Rep 168
So on the 2020 M550 you will need to remove the brace if you want to remove the air box for vacuumed cleaning? Can you re-use the plastic trim buttons or should I get some new ones or can I get that bolt out on the front of the brace by just lifting the trim cover slightly?
10-12-2023, 10:41 AM | #5 |
Rep 80
Yeah, I found out that you have to remove the braces and then it is free to replace. I didn't have to replace any clips or anything
10-12-2023, 10:44 AM | #6 |
Rep 168
So it is necessary to remove the brace over the top of the air box if you want to vacuum out any debris? Can I just lift the trim flap that covers the bolt on the front of the braces or will I need to remove and replace the trim buttons that holds it down? Looks like I am going to have to get a Torx socket for the back bolt on the brace?
Thanx!! |
