06-22-2023, 08:18 AM | #1 |
Rep 30
Replacing front bumper parking sensor… how to
Hi all, a rock hit one of my parking sensors and needs replaced. I ordered a new sensor to get it replaced. Has anyone done this before in this particular location? I am wondering if I need to remove to the grill or can I get it replaced without doing that? Thanks in advance!
06-22-2023, 06:51 PM | #2 | |
Rep 332
06-23-2023, 09:14 AM | #3 |
Rep 30
07-01-2023, 08:32 AM | #4 |
Rep 30
Fyi I was able to easily replace the sensor myself. No need to take off the grill.
Here the steps 1. Remove the wiring harness that snaps in to the sensor (squeeze down on clips and pull) 2. Get a small flat head screw driver, and push in to the clips on the top and bottom of the sensor (in the main housing, the rectangular part, you notice a clip on the top and bottom, you can feel them when reaching in). You can push on the sensor from the outside at the same time with your thumb. 3. Once it pops out, re attach the wiring harness from number one in to the new sensor and then push back in to place. I would recommend cleaning the new sensor with a microfiber cloth, after install, in case it got dirty while installing. |
08-28-2023, 08:52 AM | #5 | |
Rep 6
Hi, thanks in advance for the help!
Got a parking sensor warning message on my '22 X7, dealer says a rock hit my left front inner sensor and it's over $1K to replace. I am fairly handy, don't mind tinkering. First question - is this the part I need? https://www.bmwdirectparts.com/oem-p...or-66209826953 Second question - what are the steps? I read the previous post - where is the wiring harness, where do I start? Thanks! Quote:
