06-25-2023, 05:15 AM | #1 |
Rep 2
Change Miles to Kilometers 2018 520D
Hi, I am in the process of importing a 520d sport from the UK to Ireland. Wondering can you change the speedometer to kilometers along with the odometer. thanks
06-25-2023, 06:47 AM | #2 |
Rep 7,584
Does it have the all digital instrument cluster? The all digital cluster can be changed by simply selecting the UNITS you want in iDrive. Depending on which version of iDrive…go into SETTINGS and look for LANGUAGE/UNIT selections which should give you options to select the scale of measure you want.
Here’s an example of LANGUAGE/UNIT selection in CIC and NBT/ID4 iDrive…later versions should be similar: MILES: KILOMETERS: Below is a screen capture of the iDrive7 owners manual for changing UNITS of measure…also accomplished by going into SETTINGS:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-25-2023 at 07:18 AM.. |
