BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Screw Marks Installing Rear License Plate
      06-27-2023, 08:46 PM   #1
Howard1485
Howard1485's Avatar
Drives: 2024 Frozen Portimao Blue M4
I wasn’t paying attention and the screws that came with the rear license plate were a bit long and left a small mark. I purchased some touch up paint from TouchUpDirect. I’m not super concerned with the matching as it will be covered by the license plate but wondering if this is necessary to prevent corrosion? For what it’s worth it’s Frozen Portimao Blue. Has anyone also done this and done anything differently to fix?
      06-28-2023, 05:11 AM   #2
Howard1485
Howard1485's Avatar
Here are some pictures of the damage for reference.
M5Rick78075.50
      06-28-2023, 05:37 AM   #3
Don't use screws! I only use double sided licence plate tape from a Honda dealer which are the best and don't peel off in rain or hot weather and the plate is flush with the body without a holder.
Just a dab of any blue car touch up will suffice for the stab marks as they are hidden by the plate.
      06-28-2023, 05:40 AM   #4
Howard1485
Howard1485's Avatar
Don't use screws! I only use double sided licence plate tape from a Honda dealer which are the best and don't peel off in rain or hot weather.
Would I use the double sided tape for both the license plate to the back bracket and for the front frame to the license plate?
M5Rick78075.50
      06-28-2023, 05:44 AM   #5
On mine the licence plates are flush with the bodywork and no holder, once the Honda d/sided tape grips it won't let go, my licence plate holders were put away in the garage and the larger holes on the trunk are covered up with duck tape.
      06-28-2023, 05:49 AM   #6
Howard1485
Howard1485's Avatar
One last question, do you know if that area will corrode being exposed? I would suspect that it is sheet metal behind there since it’s the trunk? Will touch up paint protect corrosion from occurring?
M5Rick78075.50
      06-28-2023, 06:00 AM   #7
So long as primer still covers the puncture marks as it appears in your pic, if you can see shiny metal then a dab of primer and when dry the colour will suffice , it is then sealed.
      07-03-2023, 06:13 PM   #8
Howard1485
Howard1485's Avatar
Here are some after touch up photos. I used paint from Touchup that actually matched pretty well but not the greatest touch up job. Anyone who has done this, is it normal for it to look uneven. I’m new to this.
      07-03-2023, 06:50 PM   #9
spazzz
spazzz's Avatar
190
Drives: 2008 535xi MHD&XHP,2013 X1 35i
That's normal. The screw created a crater.
Usually a toothpick dabbed into the crater would do it. I never use the brushes that come with touchup.
I buy 00 artist brushes and use a baggie as my paint tray. You can practice on the baggie before you hit the spot.
Without sand paper before and after it is almost impossible to get it perfect.
But what you did serves the purpose. Did you wipe the area with a paint prep before the paint went on?
The dipshit who owned my X1 before me cranked a sheet metal screw right through the metal, securing the plate. Made their mama proud on that one. I used JBWeld to plug it
      07-03-2023, 06:53 PM   #10
Howard1485
Howard1485's Avatar
The dipshit who owned my X1 before me cranked a sheet metal screw right through the metal securing the plate. Made their mama proud on that one. I used JBWeld to plug it
I wiped with some cleaning/prep cloth. I used primer since I saw some metal. So primer/color/clear.
spazzz189.50
      07-03-2023, 08:26 PM   #11
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
You're 100% good to go.
I use screws but I did buy some I knew were long enough to hold the plate but short enough to not poke through the plate holder. It's still an option for you.
https://www.amazon.com/dp/B07D5S553C...roduct_details
For my 135i. Not sure about any other cars.
      07-05-2023, 06:45 PM   #12
NickyC
NickyC's Avatar
20302
Drives: M4 CS. Former G82, x2 F82, F80
If it's any consolation to you, at first I thought you were talking about the indents in the black VIN tape and didn't even notice the scratches you were really talking about.
      07-05-2023, 08:09 PM   #13
jkoral
Drives: 2017 M2 LBB 6MT
Was surprised to find my 2022 X3 came with BMW plastic screws for the license plate, no risk of scratching:
https://www.fcpeuro.com/products/bmw...al-07146959895
(Not sure about the fitment on the FCP page -- I had a 135i that used the same screws as you posted).
There are no longer threaded inserts in the plate bracket: https://www.fcpeuro.com/products/bmw...BoClcwQAvD_BwE
      07-06-2023, 05:21 PM   #14
Howard1485
Howard1485's Avatar
I decided to bring my car to an auto body shop to do the touch up. They seemed pretty confident that I wouldn’t know when they’re done. Has anyone had touch up performed by a professional and what were the results that they saw?
      07-06-2023, 05:41 PM   #15
shiftdnb
shiftdnb's Avatar
Drives: 2017 F31 328dx
honestly I wouldn't worry too much about how it looks because it will be covered by the license plate. The true need to fix it would be to prevent it from rusting and spreading underneath the paint.
      07-06-2023, 07:16 PM   #16
Howard1485
Howard1485's Avatar
Unfortunately I’m a little OCD haha. I was curious how good touch up paint will be done by a professional. I’ll post some pictures if anyone is curious.
      07-06-2023, 07:28 PM   #17
Oh the humanity...
      07-18-2023, 04:44 PM   #18
Howard1485
Howard1485's Avatar
Auto body shop definitely did a better job than I did!
      07-18-2023, 05:09 PM   #19
G35POPPEDMYCHERRY
G35POPPEDMYCHERRY's Avatar
Drives: F80
for what its worth, it was less noticeable before touch up. now thats just my opinion not shitting on you and your car and your ocd
sometimes leaving it is better than touch up IMO
      07-18-2023, 06:12 PM   #20
Howard1485
Howard1485's Avatar
I realize many on here are rolling their eyes haha but figured it might help someone decide between doing touchup themselves or having a professional do it. Or maybe not do anything at all. Only reason I wanted to do something was because of the metal showing and at least wanted to protect it.
      07-19-2023, 04:42 AM   #21
Gladius Nova
Gladius Nova's Avatar
87
Drives: G20
  [0.00]
I'm OCD to a point, but this is a first world problem.
      07-23-2023, 07:57 AM   #22
fcman
Drives: 2023 G87
I used Dr Colorchip on a few rock chips on the front of my C7 corvette. I put the paint on and left to let it dry and then came back to wipe them as instructed and not even lying I couldn’t even find most of them anymore. That stuff is absolute magic.
