07-10-2023, 06:49 AM | #1 |
Rep 1,475
F31 Rear End Erratic
I've got a 2012 F31 Touring RWD, with stock shocks and lowered Eibach pro kit (was lowered about 3 years ago) and with relatively new tyres on the rear (Goodyear Asymmetric 2s).
Recently, over the last month or so, I've noticed that at high speeds on the motorway going over bumps that the back end kicks out. This can be in any driving mode, and is really unnerving. I regularly check the tyre pressure and ensure the bolts are tightened properly. The shocks or springs haven't caused any issues in the past. The only two possible things I can think of are 1) the goodyears are not great tyres (I've previously stuck to MP4S) or 2) the auxiliary shock absorber (the rubber thing on the shock) has disintegrated, but this has been like that for a while. Anyone come across this before?
07-12-2023, 03:20 AM | #3 |
Rep 8,522
Is the car still on BMW OEM dampers ? They are renowned as being woeful and probably can’t handle the demands of stiffer and shorter springs.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
07-12-2023, 11:00 AM | #4 |
Rep 787
At that age/mileage it would be good to check for blown struts, bump stops, and sway bar bushings/end links. Are these all original parts?
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
07-12-2023, 07:19 PM | #5 |
Rep 1,475
I am indeed on stock shocks, they've done 86k miles and never been changed as far as I know (and I've had the car 4 years now).
Other than the springs, everything else is original. Sounds like I need to get new shocks etc, good time to get some coilovers methinks.
danb19792015.00 |
08-06-2023, 10:36 AM | #6 | |
Idiotic lifter of heavy stones...
2015
Rep 2,195
Drives: 2015 F31 325D M Sport touring
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
08-07-2023, 04:37 PM | #7 |
Rep 12
+1 to blown shocks
Polo088161616.00 casualDIYer447.50 |
08-08-2023, 08:43 AM | #8 |
Rep 1,475
Haven't got around to fixing, but you guys were quite right. I had a look underneath and the rear passenger (left side) shock is leaking.
I've got to get her in to get them replaced, but will most likely opt for coilovers instead of the stock BMW option.
danb19792015.00 CopyRunStart120.00 |
08-08-2023, 09:35 AM | #9 | |
2015
Rep 2,195
I've just had the geo tweaked on my F31 this morning; front toe'ing in a lot; rear toeing in on the rear drivers side too much; all as it should be now and it drives so much better A blown shock won't be doing you any favours though
SuperHamz742.00 |
08-10-2023, 02:17 AM | #10 | |
Rep 1,475
danb19792015.00 |
08-10-2023, 03:25 AM | #11 |
2015
Rep 2,195
They didn't offer anything for my 325D either; but they do... Just drop them an email
SuperHamz742.00 |
08-12-2023, 09:07 PM | #12 |
Rep 1,372
+1 on blown shocks.
I've heard KW and Koni Sport tend to have longer life than other makes but honestly, dampers do die over time. If you've got 86,000 miles, I'd say at least one damper, likely the front driver side, is dead and another is half dead. On short sport springs, definitely you've killed at least one or more dampers. As for tyres, as annoying as it is to admit it, Michelin does make very good tires. Goodyear . . . more like Good-God, as in Good God man, what the hell are you doing?!
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
Polo088161616.00 |
08-14-2023, 08:07 AM | #13 | |
Rep 3,958
However, I really do like the GY Super Car 3 (220TW) tires for the track as a lapping tire that can handle a lot of heat with decent endurance. |
08-14-2023, 10:05 AM | #14 | |
2015
Rep 2,195
I chose them on the back of those reviews and glad I did; they've been absolutely superb on my F31 Tyres; like oil & brakes etc, are a very personal choice though Some will love one brand over another etc
