07-16-2023, 11:00 AM | #1 |
Rep 7
Drives: 2024 BWM X5 50E
Tesla and electrify America adapters
Hi - another charging question. We have had our 50e for a week now and continue learning more about charging options.
We have been using Chargepoint stations without issue but want to expand our options. There is an electrify america based charging station closest to our home but best I can tell, these are DC chargers (they have 2 different connector types at each station). Question 1: Does anyone make an adapeter the will allow us to use these chargers on our 50e? It seems Tesla has a different type of connector as well? Question 2: Would this adaper let us use dedicated Tesla charging stations? [Only for J1772 EVs] Lectron - Tesla to J1772 Charger Adapter, Max 40 Amp & 250V - Compatible with Tesla High Powered Connector, Destination Charger, and Mobile Connector Only (Black) https://a.co/d/5mJCfTI Appreciate the patience and help while we continue to learn about our new toy |
07-16-2023, 11:21 AM | #2 |
Rep 3,761
50e cannot do DC fast charging. L2 AC is the fastest it will accept. The Lectron adapter is for Tesla destination charger (L2 AC) to adapt to J1772x so you can charge 50e. You cannot and should not use it at Tesla super charging stations.
Bmwx5z117.50 |
07-16-2023, 04:01 PM | #3 |
Rep 6,948
A BEV will typically have a much larger battery, and because it doesn't have the ICE backup, having a quicker way to recharge is critical...thus, most all of them can be recharged slower with ACV, or faster with DCV. While the Tesla connector supports both, the J1772 uses two differently shaped plugs...the base connector does ACV, but the add-on bulge adds two HVDC contacts. Feeding HVDC into your 50e, if you managed to make it happen (tough, as the connectors are different and the protocol is too), you'd fry the electronics and maybe start a fire.
07-17-2023, 06:25 AM | #4 |
Rep 8,900
Drives: eVeRyOnE mAD!
as mentioned:
Tesla Destination Charger stations (AC) = compatible with 50e Tesla Supercharger stations (DC) = NOT compatible with 50e |
07-17-2023, 11:00 AM | #5 |
Rep 2,507
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
do not use an adapter to charge via a Tesla AC charger. If anything goes wrong and it is determined that using an adapter caused the issue, there is a risk that your warranty will be voided.
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser 2011 E90 M3 ZCP Past: E90 328i, F10 535i, F80 M3 (murdered) |
07-17-2023, 11:08 AM | #6 | |
Rep 8,900
question is don’t they need to prove the adapter caused the issue in order to void a warranty claim? |
07-17-2023, 11:43 AM | #7 | |
Rep 2,507
2018 F80 M3 CS
07-17-2023, 12:11 PM | #8 | ||
Rep 8,900
BMW is part of the EVGo network. if they claim use of third party accessories invalidates warranty claims, how are those chargers exempt? |
07-17-2023, 12:13 PM | #9 |
Rep 3,761
But isn't it too far of reach on the assumption?? Like saying if you use a non BMW brand oil, you can void warranty?
First having the adaptor in trunk doesn't mean it has been used. Like having a gun doesn't mean you have killed someone. Then they also need to prove L2 tesla EVSE can actually damage anything at all, which can only be proved otherwise. Now if the detected a high voltage DC damage, I think this is the only possible reason to void warranty
2022 G05 B58/PHEV
+ a few very old BMWs |
nZtiZia4777.50 |
07-17-2023, 12:38 PM | #10 | |
Rep 2,507
2018 F80 M3 CS
07-17-2023, 02:30 PM | #11 | |
Rep 373
07-17-2023, 04:09 PM | #12 |
Rep 3,761
Not even “basically” the same. The L2 handling is exactly the same. Tesla car can use adapters on J1772 to charge itself. Tesla themselves now also make a J1772 EVSE with a Tesla adapter.
07-17-2023, 04:16 PM | #13 |
Rep 2,507
I'm just providing the information, I'm not arguing anything. Do what you wish with the information
2018 F80 M3 CS
07-17-2023, 04:42 PM | #14 | |
Rep 1,238
Just find it hard to believe. And to be honest, there is no way that they can prove that you have used or not used any adapter. And it is inevitable that BMW would also switch to Tesla charger (NACS) in the future for North America, and adapters would be the norm. |
07-17-2023, 04:50 PM | #15 | |
Rep 20,419
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
07-17-2023, 08:02 PM | #16 |
Rep 373
Agreed. Just pointing out that it's often hard to diagnose a failure like that after the fact without access to the charger data, and the same identical failure could come from a Tesla or a non-Tesla charger pretty easily. Maybe the takeaway is don't share with the dealer the details of your charger.
07-17-2023, 08:23 PM | #17 | |
Rep 2,507
2018 F80 M3 CS
07-17-2023, 09:25 PM | #18 |
Rep 3,761
Tesla does make a J1772 wall charger tho
https://shop.tesla.com/product/j1772-wall-connector And I don’t think J1772 is capable of making any communication to the car other than pilot signal to negotiate charging current. |
07-18-2023, 04:37 PM | #19 |
Rep 6,948
Other than interlocks, acv charging with J1772 is pretty dumb.
There's a bit more info passed with CCS charging, but the X5 doesn't support that. Tesla has the ability to exchange data with the vehicle via serial data path to authenticate the use of one of their units. While I've not used it, the Tesla to J1772 adapter I have says to attach the adapter and wait for it to communicate with the unit before attaching it to the vehicle. I bought it on a whim on sale for that just in case situation where I was going to be overnight with a Tesla destination charger, or visiting a friend that was willing to let me recharge while there. |
