07-21-2023, 12:18 PM | #1 |
Rep 30
Drives: 2024 X5 M60i
Problems with Charging - Electrify America Home Wall Charger
Just took delivery of my 2024 iX M60 last week. Love the car. Coming from a X5 M50i, I miss the V8 sound but on the other hand I don't! The car is just smooth as glass and so well appointed.
I'm charging my car at home using an Electrify America Gen2 wall charger. For the first few days, there were no issues with charging. About 4 days ago, my charging sessions would suddenly just stop. Sometimes 4-6 minutes after starting the charge, but occasionally 25-30 minutes after charging started. No explanation in the MyBMW app other than "charging interrupted." I usually charge my car when it's about 50-55% charge left, and set the 80% charge maximum. I called Electrify America's support people and they checked my charger via an online connection. It seems to be working just fine. I then called BMW iSupport and went through the whole story with them. Their suggestion was to "see the dealership to have the car checked out." I plan to do that, but I thought I would hit the forum to see if anybody has seen similar issues with charging at a home station. I've tried charging with the car unlocked, the car locked, the auto "lock and unlock" with the digital key turned off, etc. No success. If anybody has seen this problem, please let me know. If you've found a solution, please share that. Rather frustrating I must say. After I see the dealer, if they find anything wrong with the car's charging system, I will post that information back in this thread. Many thanks! |
07-21-2023, 12:30 PM | #2 |
Rep 1,511
Drives: 2023 iX xDrive50
I'm not familiar with the Electrify America Gen2 wall charger but I'm assuming this is a plug-in model? If so, try setting a lower charge speed and see what happens. It's not entirely unheard of that a plug-in EVSE stops charging because of a GFCI or thermal trip. If it's hardwired, I would only suggest trying a different EVSE in a different location to see if you run into a problem. It's much more likely something is going on between the EVSE and the circuit breaker than a problem with the car so you'll want to rule that out first and save a trip to the dealer.
Past BMW's
2020 M850i GC | 2020 X5 | 2018 M550i | 2017 X5 | 2014 535d | 2013 X5 | 2007 530i | 2002 X5 | 2000 540i/6 | 1999 M Roadster | 1989 535i | 1984 533i | 1983 533i | 1977 530i |
pfiedler13.50 |
07-21-2023, 02:56 PM | #4 |
Rep 443
I probably have the same EA charger. Mine had a flaw where the unit could only charge at a low amp speed. EA notified me it was from a bad batch and shipped me a replacement. It’s worked fine since.
Try powering off the EA charger for a minute and powering back on at the circuit breaker. Assuming it’s plugged into a 14-50 outlet would check that it’s not nuisance tripping if you have a GCFI switch installed at the breaker. |
pfiedler13.50 |
07-21-2023, 03:26 PM | #5 |
BMW Aficionado
1381
Rep 1,850
I'm very sorry to hear you are having issues with this charger. Unfortunately rom what I'm reading here it sounds as if their home chargers are just as reliable as their DCFCs unfortunately.
Assuming this is a NEMA 14-50 wallbox, why not try charging with the included portable wallbox from BMW to see if you have the same issue with another wallbox or the same results. This will tell you with greater certainty if the issue is on the vehicle or wallbox side. I had issues with my X5 45e giving me the same type of charging errors / scenario and it turned out not to be the vehicle with the J1772 Cable of the wallbox |
pfiedler13.50 |
07-21-2023, 04:56 PM | #6 |
Rep 30
My charger is hard wired directly to my electrical panel. I have a 50 amp breaker and have the charge rate set to 48 amps. The BMW iX support person I spoke to said that the 48 amp setting was fine.
07-21-2023, 05:01 PM | #7 |
Rep 295
Breakers can safely handle about 80% of their rated capacity. That is the reason why there should be the 20% buffer. 60amps rated breaker can safely handle 48amps. 50amps for 48amps is pushing it.
07-21-2023, 05:03 PM | #8 | |
Rep 30
I did install a Uniden R8 radar detector and a Garmin dash cam. Both are taking power from a 12v source at the mirror. With the iX, power to the mirror stays “hot” for several minutes after leaving the car. Perhaps this is contributing as the electric cars especially have a very sensitive CANBUS electrical environment. I have an appointment Monday at my dealer to get this checked out. I’ll just have to keep experimenting until then. 😵‍💫 |
07-21-2023, 05:05 PM | #9 |
Rep 30
Okay, I’ll try backing the amps down and see that helps. Thank you for your suggestion! 🙏👍
07-21-2023, 05:47 PM | #10 |
Rep 1,511
The BMW support person should have known better. A 50 amp breaker will support 40 amp at the EVSE. You’re limited to 9.6kW and anything higher will lead to problems.
Past BMW's
pfiedler13.50 |
07-21-2023, 05:50 PM | #11 |
Rep 30
07-21-2023, 06:16 PM | #13 |
Rep 30
07-21-2023, 06:56 PM | #14 |
BMW Aficionado
1381
Rep 1,850
depending on the AWG wiring used to hardwire your unit as well as the distance from panel to wallbox, you can possibly swap out the breaker to an appropriate 60A given the wiring is thick enough to be safe for that current draw to get the full 48A
pfiedler13.50 |
07-21-2023, 07:50 PM | #15 |
Rep 3,079
Drives: 2023 iX M60 Oxide
Probably not helpful but a good chunk of the Tesla gen 3 wall connectors manufactured in 2019/2020 did this. It was due to overheating of the wall connector. It would charge fine for a bit and then stop with a red blinking light. When it cooled down it would start up again, and cycle like that.
I only mention it because it may be something similar with the EA. As others might have suggested maybe you can try lower power or using the stock power cable that is included with the car to prove it’s something with the EA one. |
pfiedler13.50 |
07-21-2023, 07:54 PM | #16 |
Rep 3,079
I missed where OP said that this was tripping the breaker and they had to reset each time, is that the case? I’d still stick to 40A max on a 50A breaker, but if it isn’t tripping then that wouldn’t explain the stop in charging.
07-21-2023, 07:56 PM | #17 | |
Rep 30
Thank you for your kind advice. 🙏👍 |
redhot47fla770.50 |
07-21-2023, 07:57 PM | #18 |
Rep 30
07-22-2023, 12:09 PM | #19 |
Rep 30
Latest Finding
A few days after purchasing the car, I had a Uniden R8 radar detector and Garmin Dashcam 67 installed. These devices tap into a 12v source at the rearview mirror.
When the car is turned off and the driver exits, power remains active to the detector and camera for about 10 minutes. This is the nature of that particular circuit, it seems. I know that BMWs have VERY sensitive electrical systems. Perhaps the fact that these stay on for about 10 minutes may impact the charging process. Today, after parking the car, I attempted another charge. As before, the charging stopped by itself after about 6-8 minutes. I then disconnected both the detector and the camera from the power source and proceeded to attempt another charge of the car. The charging process went through without a hitch. Soooooo...maybe this is where the problem lies? I'm hoping that the car throws error codes so that when I go to the dealer on Monday morning, they may see some indication of what's happening. Fingers crossed!! |
07-22-2023, 12:33 PM | #20 |
Rep 3,079
I would be quite surprised if it had something to do with the 12v accessories. Really I think you need to find an alternative AC charger to really tell if it’s the car or the EA kit.
Pictor1733.00 |
07-22-2023, 12:53 PM | #22 |
Rep 377
I haven't read the full thread, but wonder why you went with a third party charger, rather than just using the one BMW supplied.
FWIW, I have a Uniden radar detector powered by an ACC circuit in the fusebox in the right rear. It stays on for 4 minutes after powering off the car. I've had no issues home charging with the BMW-supplied charger. |
pfiedler13.50 |
