07-27-2023, 10:27 AM | #1 |
Rep 7
Drives: 2013 335i
Steering Wheel and Wheel won't fully turn to the Left
BMW - 2018 - 340i
I recently dropped my subframe for some maintenance. I go to test the car and it does only one full rotation to the left then it stops allowing me to turn. While the right it can go the full 2 rotations. Any ideas or things I can check, would be greatly appreciated! |
07-28-2023, 04:47 AM | #2 |
Rep 8,524
Do you have adjustable drop links on the front anti-roll bar ?
Check that the ARB isn’t in the way of the left hand track rod end, which can happen especially if the car is lowered, and adjust the drop link if needs be.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Hyper+F300.00 |
07-28-2023, 06:34 AM | #3 |
Rep 7
Drives: 2013 335i
Car is on factory suspension but I will check if the ARB is in the way. Thank you for the response.
Is it possible the streering column is on a way different spline resulting in this issue? |
07-28-2023, 09:07 PM | #5 |
Rep 7
Drives: 2013 335i
I believe it was 3, how do I go about adjusting the steering rack.
Thank you |
07-29-2023, 12:27 AM | #6 | |
Rep 43
Could be hard to do with the rack on the subframe. You can go by feeling and try with someone holding the steering wheel. |
Hyper+F300.00 |
07-29-2023, 07:07 AM | #7 |
Rep 7
Drives: 2013 335i
Yup saw that video and feared of dropping my subframe again car is currently with the family mechanic if he can’t straighten it out I guess I just drop it again.
Thank you! |
