07-30-2023, 08:39 AM | #1 |
Rep 435
Drives: BMW G87 M2, F25 X3
Winter wheel options (G42 to G87)
Hey folks... Just got an allocation and expecting winter delivery in Vermont so I am trying to figure out tires.
Looking for some advice/objective perspective from the knowledgeable folks on this forum. The G42 I am trading on has a square setup with 19x9" ET25 Apex VS-5RS that currently have 255/35-19 PS4S mounted for summer. For the G87 I will need winter tires right away, so figure my option are: 1. Try to find winter tires that fit the stock G87 wheels, preferably run flats. This is appealing because they are cast heavy wheels, but I am concerned about even finding winter tires at this size. Sell the Apex wheels and buy some new wheels after I have worn out the stock summer tires. 2. Run the amazing VS-5RS with winter tires. I think I can find some 245/40-19 run flats if not 255/35-19. I love these wheels, but I feel a bit silly running them on the salty Vermont winter roads then putting back on cast wheels for summer. 3. Buy some other winter wheels. What would you do? |
07-30-2023, 06:37 PM | #4 |
Rep 3,033
apez656.00 |
07-30-2023, 06:49 PM | #5 |
Rep 1,510
Drives: G87, G26, E46, Mk6 5K
They got some Pfunks in our size.
M_Power Rob3763.00 apez656.00 |
07-30-2023, 08:38 PM | #8 |
Rep 3,033
07-30-2023, 08:41 PM | #9 |
Rep 1,547
I assume you don't want to run the Apexes in summer because they are only 9 inches? Limiting you to, what, 275mm or less?
If I was you, I'd go with a tire swap onto the stock rims, and sell the Apexes. However, I'd personally go with non RFTs because (in Boston) I've found RFTs to be too stiff and they tend to cause bent rims on potholes. But YMMV, that's just my personal taste. I'd also bank the cash from selling the VS-5Rs and buy new VS-5Rs next year as a permanent summer set (staggered). I don't like the stock wheels very much, TBH. Heavy, hard to clean. |
apez656.00 johnnie311197.50 |
07-30-2023, 08:49 PM | #11 | |
Rep 435
Exactly, too small for summer. I think this is probably my move as I love the wheels on my g42 - at least if I can find tires. I was thinking RFTs just in winter because plugging a hole in salty, wet, slush sounds awful. I totally agree that RFTs suck compared to go flats, especially ride quality. |
07-30-2023, 09:43 PM | #12 |
Rep 1,510
07-31-2023, 10:26 PM | #14 |
Rep 1,547
08-14-2023, 05:26 PM | #15 |
Rep 261
Winter Tire/Wheel Set for M2
Check out Tire Rack's write up on running smaller...higher tires for winter performance...Summary: narrower tires don't aquaplane as much in the wet and handle the frozen forms of water better
Bonus...higher aspect ratio = more sidewall to handle potholes filled with rain or snow... So grab a set of take off's from a 230/240/330 with 19" wheel upgrades..you get 19x8 27mm offset wheels style 783...heavy Chinese castings! Run 225/45-19 tires and your within 0,30" of the stock rear 20" tires! Plus you can pick up a set of these almost new for less than $1K....so plenty left over to by snows or whatever. I took these wheels off my new 230i X drive to put on some BMW stock 18's and run 225/45 all season NRFT tires instead of the 225/40 RFT "rocks" that came with my car! Don't need 10/10ths performance anymore (reflexes and eyes aren't what they used to be)...Bonus..wife likes the smoother ride! Last edited by spitpilot; 08-14-2023 at 05:31 PM.. |
08-25-2023, 06:06 PM | #16 |
Rep 42
If anyone finds a tire rack wheel that fits and well suited for a winter tire, please share a link! I’d appreciate it.
stashstein210.00 |
08-26-2023, 08:15 PM | #17 | |
Rep 1,547
However, I do worry about fitment on non-oem sizes. Lots of people running into fitment problems against the strut or fender linings. Also the G87 oem offset is only 20mm. I would worry that 27mm will pull the wheel in too close to the brake hardware or strut. |
08-26-2023, 08:18 PM | #18 | |
Rep 1,547
If you can live without running a pure winter, there are Michelin Pilot Sport All Seasons available in OEM sizes, both front and rear. That's the simplest answer because it avoids all issues of fitment and sizing. The downside is that your M2 should stay home in bad storms. |
08-26-2023, 09:29 PM | #19 | |
Rep 3,026
Drives: A Family Sedan
08-26-2023, 10:27 PM | #20 | |
Rep 42
08-27-2023, 08:54 PM | #21 |
Rep 435
Interestingly, BMW's winter tire/wheel packed seems like it comes with winter tires that would fit the stock wheels...
https://www.shopbmwusa.com/product/1...-JET-BLACK-UNI Wheel Set Specifications: Rims: BMW Style 826M Tires: Michelin Pilot Alpin 5* Tire Dimensions Staggered Fitment F:275/35R19 100V XL R:285/30R20 99V XL So maybe the question is if we can source these independently. |
M2siast5949.00 |
08-27-2023, 11:25 PM | #22 | |
Rep 3,026
