BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Tire Pressure Readings
      08-03-2023, 06:36 PM   #1
ifletch
Drives: 2016 BMW X1 xDrive28i xLine
This is my first car with tire pressure monitoring with actual pressure values and I am just wondering if it is normal for the reported values to be higher then tire gauge readings? The reported values were very high from the dealer/factory. So I measured them cold with a decent intercomp tire gauge and they were very high. The door frame says 32 PSI and they were up as high as 39 PSI. I have lowered them all to 32 PSI but the reported values in the car say 35PSI with a recommended pressure of 31PSI. Why is the computer recommending 31 PSI when the door frame calls for 32 PSI?
      08-03-2023, 07:01 PM   #2
allinon72
allinon72's Avatar
Drives: 20' M2C, 23' X1
Recommended pressure is based on weather conditions.
      08-04-2023, 07:42 AM   #3
tex2670
tex2670's Avatar
Drives: '23 X1 28i xDrive
It shouldn't be that far off. You may want to get another manual gauge to double check. But always measure when the tires are cold
      08-04-2023, 08:44 AM   #4
skyboum
Drives: BMW X1(U11)
The tyre pressure monitoring is so annoying... It starts to complain about every little change to the pressure which is normal in the hot weather here. I'm so tired of it that I drive with the warning all the time.
      08-04-2023, 10:35 AM   #5
Pganders
Drives: X1 M Sport 30e
That’s strange and looks like something might be wrong. I haven’t had a tyre pressure warning yet in two months driving the car.
I’ve got my tyre pressures set cold at 31psi using my own pressure gauge and depending on temperature/weather the pressures for all four tyres viewed via the app can range up to 36/37psi after a journey without any warnings flashing up in the instrument panel. They are always within 0.5psi of each other.
Are all four tyres showing the same pressure?
      08-04-2023, 11:17 AM   #6
skyboum
Drives: BMW X1(U11)
No, each shown different tire pressure.
      08-04-2023, 12:03 PM   #7
Pganders
Then there is something wrong. If you’re starting off with tyres all the same pressure they should stay that way as the pressure rises with temperature, certainly I think within a tolerance of +-0.5psi.
      01-13-2024, 02:59 PM   #8
COOLGREANY
Riding BMWs since 1976
COOLGREANY's Avatar
169
Drives: 24 xDrive28i Space Silver
Just picked up our MY24 28i.
Tires are Bridgestone Turanza 255 55R18.
Checked the tire pressures and when I got home and they were all set around 40 psi.
Both the manual and the vehicle door label indicate the tire pressure should be 35 front 32 rear.
The mobile app is showing the recommended pressures to be 39 front and 33.9 rear.
I'm assuming that the App is factoring in temperature? It has been around 70F here today which is fairly close to what I would expect to be ambient temperature.
2024 X1 xDrive28i (Space Silver), 2014 BMW X1 (E84) (sold), 2010 MINI Cooper S Clubman, 2011 BMW R1200GS Motorcycle and various BMW motorcycles since 1976
      01-13-2024, 03:07 PM   #9
SpaceSilver.X1
world's slowest BMW driver
1554
Drives: U11, G60, W211, AZ20
the recommend and current tire pressure readings on the in-car display and the app both vary quite a bit depending on ambient temperatures. A couple of weeks ago, my area had wild temperature swings.(68 during the day and 25 at night) The sensors appears to factor this in, as my tire pressure readings almost always matched the recommended values.
Each tire may also have different reading. For example, if you parked in your driveway and the sun is on the left, those two left tires will be warmer, resulting in different recommend/current pressure.
that's assuming the pressure was correct when they calibrated the tries at the factory or during PDI. I checked the pressure of all 4 tires with two different gauges(a BMW one and a JACO one) and they matched the TPMS sensors.
Don't forget to check the spare tire pressure as well... mine was really, really low when I checked it.. more than 10 psi lower than the recommended 60psi.
