08-05-2023, 01:09 PM | #1 |
Rep 101
Original intake - modified?
Hi
Is it possible to modo\ify the original intake to make it less restrictive? Is there some channels/restrictors that may be cut out to make the engine breath easier? Or is there no point in doing this? |
08-05-2023, 02:44 PM | #2 |
Rep 297
I’ve seen intake “upgrade” parts such as intake pipe hose, turbo inlet pipe, and intake muffler delete. And of course, higher flowing drop-in air filters. No idea if all of this would result on more turbo noises. I’m guessing that there likely wouldn’t be much (if any) noticeable performance gains.
For me I think it makes more sense to get a full like intake that can be sealed like BMS / Dinan. |
08-06-2023, 09:42 AM | #3 |
Rep 962
Drives: G87 M2, G20 330d, Brabus Smart
The gains from modding the stock intake are nominal, at best. I went through several options on the F80 platform, and ultimately the best combination of added sound/performance was a Burger Motorsport intake, with just the open filter and pipe under the hood. Sure, I'm sure a sealed system would result in more cold air, but I enjoyed the added turbo and induction sound gained. Just my 2 cents.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
nype139.50 |
08-06-2023, 10:08 AM | #4 |
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
Depending in the country you live in, there’s good chance the intake has a charcoal filter sitting in front of the air filter. This can be easily removed to increase air flow (in theory). It’s not there to improve filtering of air going into the engine but apparently only serves to filter any emission gasses that could come backwards into the environment (not sure how but I’m guessing when the car is turned off maybe?)
08-07-2023, 10:30 AM | #6 |
Rep 525
Stock airbox system is very good, you'll need to go to something comprehensive that enlarges the turbo inlets to see a performance gain. You want to keep a sealed system, anything opening up to engine bay air may increase sound but will suck in hot air.
The low hanging fruit is a high flow panel filter, and removing the charcoal filter f you have one. |
