BIMMERPOST Universal Forums General BMW News and Cars Discussion Vehicle PPI results are out!
      08-05-2023, 09:22 PM   #1
chancellorbeem
Drives: 20' M850i Coupe
Hi all, I’m considering a 2019 m850i and here are main issues found.
  • Slight vibration felt through brake pedal when braking
  • Engine coolant smell but no visible leakage
  • Battery low state of charge
Are these issues I should be concerned about?
      08-05-2023, 09:35 PM   #2
chassis
chassis's Avatar
8592
Drives: 9Y0 Cayenne S
First and third items are the dealer trying to generate revenue from you to replace the brakes and battery. Neither seem serious.
Engine coolant smell could be normal, depends on the vehicle. MBs for example "sweat" coolant at the hose joints, and coolant smell is common. Search the forums for coolant smell. It could be normal, or it could be a water pump or cylinder head gasket making its way to Heaven.
      08-08-2023, 08:54 AM   #3
chancellorbeem
Originally Posted by Efthreeoh View Post
Used car that's been sitting awaiting to be sold. Low battery because the car has not been driven enough to keep the battery fully charged. Brakes have surface rust causing vibration. Have the cooling system pressure tested.
I’m guessing just using the brakes will remove that?
      08-08-2023, 09:53 AM   #4
Oldgixxer
Oldgixxer's Avatar
2086
Drives: nothing fast
Beware the Hot Vee! That very same drivetrain in my '20 M550i was plagued with issues and the vehicle was brand new off the dealer lot. That coolant smell(and subsequent leakage)is a common issue,was back to the dealer 13x in 1.5yrs for warranty work for that,as well as other issues.
Make sure you have ALL the extra add-on warranty you can afford to purchase chances are you'll need it...
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582)
Gone but not forgotten:
-'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG
      08-08-2023, 02:32 PM   #5
chancellorbeem
Yep dropping 6k on the warranty extension 3 year
      08-08-2023, 03:09 PM   #6
RonronEG
Drives: BMW 540i
I believe in the newest revision to that motor the coolant lines to the turbos should be stainless steel not rubber hoses. Id check that out- seems to be one of the biggest issues with the N63
Oldgixxer2086.00
      08-08-2023, 03:34 PM   #7
chancellorbeem
I will go ask about those after taking delivery.
      08-09-2023, 07:32 AM   #8
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
I can't say for all cases of course but historically I've seen "warped" rotors (pedal vibration) turn out to be pad deposits on the rotors that can be scrubbed off with a couple aggressive stops from higher speeds. If there's a test drive option without a sales person present, maybe give it a try (be safe)? If it works, there's really no issue, but if they don't know that it might still be some leverage with the seller?
I don't think the seller was ever explained - the dealer, a different dealer, private party, Carmax...? This might factor into the overall situation.
      08-09-2023, 09:26 AM   #9
chancellorbeem
It’s an independent used car dealer.
He said there was a spot on the rotor that was removed and the issue was fixed. I will be going there in person so will see haha.
      08-09-2023, 09:46 AM   #10
Oldgixxer
Oldgixxer's Avatar
2086
Originally Posted by chancellorbeem View Post
It’s an independent used car dealer affiliated with Honda and service Mercedes.
I'd immediately be suspicious and walk away from buying a used BMW(even more so if service records from original owner are not included) from a non BMW dealer,I've seen more than enough situations where that ultimately proved to be a huge mistake.
This is strictly 100% my opinion,so take it w a grain of salt
-'24 X5MC,'22 430i
xander_g1112.00
      08-09-2023, 12:48 PM   #11
xander_g
Drives: G30 M550i
Had the coolant smell issue, followed by low coolant warnings. This issue merits coolant line replacement.
Oldgixxer2086.00
      08-09-2023, 01:04 PM   #12
chancellorbeem
Did BMW replace it with just the same parts? Or do they upgrade it to a different material.
      08-09-2023, 01:06 PM   #13
chancellorbeem
Yes, I was very skeptical as well. However, this car does have all the options I want and got a reasonable price plus trade in. The dealership rating seems pretty solid as well and the communication has been clear. Had a thorough PPI done as well.
I will be getting the extended warranty so not too worried but just annoying to deal with fixing potential issues.
      08-09-2023, 08:07 PM   #14
xander_g
Drives: G30 M550i
Upgraded lines, aluminum I believe. They also changed hoses, and the thermostat + housing.
