08-06-2023, 10:05 PM | #1 |
Rep 121
TPMS Sensor Help!
Looking to swap my wheels to 20s and looking to get a set of TPMS sensors (2023 X5).
I saw a few members recommend this listing on eBay in the past - is this still a legit source? Anybody else can recommend going another route as this one might take 1+ months to arrive to the USA. They will already come programmed? Thanks!! https://www.ebay.com/itm/25313670922...Bk9SR8K-0d65Yg |
08-07-2023, 02:04 PM | #2 |
Rep 7,590
Any national tire chain should be able to get the correct TPM sensors...call and inquire about a price check.
Here's some examples from my local area:
Or...you can type a keyword phrase into a google search to find other vendors that sell either the OE or equivalent aftermarket TPM sensors like HUF & BERU. Here's an example...simply copy and paste the following phrase into a google search box...its the 11 digit BMW part nbr and name of well known aftermarket manufacturers of compatible TPM sensors: BMW 36106876957 BERU HUF
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-07-2023 at 02:12 PM.. |
08-07-2023, 03:05 PM | #3 |
Rep 10
Got mine from here: https://www.ebay.com/itm/11357039231...mis&media=COPY, which is also recommended by some members here. No problem so far.
08-07-2023, 03:19 PM | #4 |
Rep 6,948
I've not found with the proper TMPS that they need to be programmed...they do need to be paired with the vehicle, but that's done in an iDrive menu...the same thing you'd do if you rotated your tires for the X5 to then know where each one is.
