08-11-2023, 09:57 AM | #1 |
Rep 125
Can someone properly code HUD for me?
Hi guys
It's a bit of a long story so please bare with me. I have a F30 330i 2016 model and I believe I need some FSC coding done. Basically I had a major accident at the end of 2022 and I had a lot of stuff replaced, including the entire dashboard. The dashboard I got came with a HUD module preinstalled as well as an extra speaker, and I can see the HUD options on iDrive, however, I don't think it's coded properly because I cannot see the actual HUD module under BimmerCode > Instrument Cluste. Also some stuff isn't working on it like navigation directions and turn signals, however I can see digital speed, limit, cruise control, warning signs, phone calls, and music selection / radio. I have screen recordings and screenshots from BimmerCode that I can share with you, along with the VIN number of my car. I also have BimmerLink and I get three errors that refuse to be cleared, and I suspect one of them has to do with something not properly coded but I am not too sure. Here's a screenshot of the 3 errors for your reference. Do you guys think this just needs some proper FSC coding done? It's odd that the HUD works fine and I can see some of its options in the Drive screen but not under BimmerCode. Here's a short screen recording of the Instrument Cluster module under BimmerCode: https://streamable.com/8vytsh I have BimmerLink, BimmerCode, as well as an ENET cable but I don't think I have Esys or ISTA anymore but I'd be willing to have someone remotely code it for me for a price. Thank you for your time and sorry for the long post |
08-11-2023, 10:04 AM | #2 |
Rep 536
RLS Sensor is not same there is more variant but you will need other winshield and RLS. To code hud you need Added 610 to your VO and code kombi,hu,hud
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
08-11-2023, 10:17 AM | #3 |
Rep 125
Is there a way to code this RLS sensor so that the error goes away? Adding 610 to the VO means I'll need to FSC code, correct? Are there any free ESYS licenses anymore or would I have to buy it?
08-11-2023, 10:19 AM | #4 |
Rep 536
esys is free and for vo coding not need any launcher which cost a money. FSC you don`t needed for hud. If you are in car I can check over teamviewer
08-11-2023, 10:21 AM | #5 |
Rep 125
Yo that would be fantastic! I am going to grab my ENET cable from my other house tonight and I'll DM you. Whenever you have time, I can use my laptop and have you connect through TeamViewer or AnyDesk for that. Would you happen to know where I can find and download Esys?
08-11-2023, 10:23 AM | #6 |
Rep 536
I am free now you need just enet cable and pc i will do it remotely
08-11-2023, 10:25 AM | #7 |
Rep 125
